Old 06-30-2024, 03:02 PM   #1
Too Slow '90
Too Slow '90's Avatar
What Year Seats are These?
I bought these a while back to install in my '60. I thought from all of the threads I read that these were a fairly easy retrofit but I don't think I grabbed the correct ones. No electrics in them. The tracks are 5"-6" longer than the factory bench and even with the track backed up all the way to the hump in the floor pan they still stick out way too far. I saw a few posts where spacers were used for the front where the floor pan drops but these just don't seem to fit.
I'm just wondering if I grabbed the wrong year. Thanks.
Too Slow '90 is offline   Reply With Quote
Old 06-30-2024, 09:22 PM   #2
dmjlambert
dmjlambert's Avatar
Re: What Year Seats are These?
I don't know what year they are, but they do look very nice. Is it possible to cut and modify the tracks to make them shorter?
dmjlambert is offline   Reply With Quote
Old 06-30-2024, 09:32 PM   #3
72Mountaineer
72Mountaineer's Avatar
Looks like 2000ish Chevy full size truck.
72Mountaineer is offline   Reply With Quote
Old 06-30-2024, 09:53 PM   #4
Getter-Done
Getter-Done's Avatar
Quick search shows (2000-2006 SUV and truck jump seat)
84 Chevy K-20
Old 07-03-2024, 03:55 PM   #5
forestb
forestb's Avatar
Are you trying to bolt them into the factory holes?
forestb is offline   Reply With Quote
Old 07-04-2024, 08:22 AM   #6
Too Slow '90
No. I would be okay with drilling new holes if they would fit the pan but they are substantially larger and don't fit in the flat part of the floor pan.
Old 07-04-2024, 09:10 AM   #7
Getter-Done
These links are just for ideas as SLOSH Tubz does not yet offer a plate for your truck Also TMI has a Frame that is an option?.
Do you have the means to fabricate a plate or bracket like the ones they sell?
Link: https://www.tmiproducts.com/pro-series/seat-brackets
Link: https://www.sloshtubz.net/store/SQUA...AME-p327471202
84 Chevy K-20
Old 07-04-2024, 09:25 AM   #8
Too Slow '90
I am sure I could fashion something. I probably misread something when I first started looking years ago. I thought it would be a pretty simple installation. I was just wondering if I bought the wrong year seats. I had the original bench reupholstered and keep going back and forth.
Old 07-04-2024, 09:42 AM   #9
Getter-Done
IMO It's hard to beat the original bench seat.
If you require better seatbelt system, I would move forward with installing the newer seat. Just my 2 cents.
84 Chevy K-20
Old 07-04-2024, 09:47 AM   #10
Too Slow '90
I like to look of the bench since the truck is mostly original. I bought a set of 3 point belts but they are giving me trouble too. So close but so far...
Old 07-06-2024, 05:25 PM   #11
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have these seats and tho they are pretty comfy, they raise you up and set you forward so if your a big fella, you will be uncomfortable driving since the wheel is in your belly.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
