Old 07-01-2024, 08:25 PM   #1
Robert Crandall
Junior Member
1978 C20 Drive Shaft Center Seal
I am not finding a center drive shaft seal for my 1978 C20. Possibly because I do not know what to call it.
The truck has the granny gear 4 speed transmission and a 2 piece drive shaft. For many years adding grease to the fitting on the splined center of that shaft only puts the amount that I add out the seal. None goes to the splines. When the truck was new (and for many years after) grease would come out of a hole at the opposite end of that splined section, letting me know when the whole length of the splines is greased. I'm getting ready to take the transmission out to replace the crankshaft's rear main seal. I want to try to change this seal as a "While I'm at it..." task.
Can anyone identify this seal, or direct me to where I can find it myself?
Thanks!
Robert Crandall is offline   Reply With Quote
Old 07-03-2024, 10:39 PM   #2
400/400
Re: 1978 C20 Drive Shaft Center Seal
Is this the seal under the threaded cap on the slip joint? I’ve seen square “o-ring” stock of the appropriate dimensions cut to fit the cap used as a replacement.
Be sure to not over tighten the cap and creat a bind.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 07-03-2024, 11:22 PM   #3
Robert Crandall
Junior Member
I like that. Thank you! I will look at that. It would be good if that is what I find. I'll update when I find out.
Old 07-22-2024, 04:46 PM   #4
Robert Crandall
Junior Member
I cut a gasket to fit (1.75 OD x 1.25 ID) of 1/16 inch rubber. It fit, but 1/16 inch thickness was not a correct choice. Grease from the fitting blew it out. The next one I make will be 1/8 inch thick.
Edit: I made an 1/8 inch thick one. It does not blow out as early as the 1/16 did, so it is better but not yet good.
Last edited by Robert Crandall; 07-23-2024 at 05:06 PM. Reason: New gasket, new thickness
