07-02-2024, 09:31 AM | #1 |
If I need a new Pressure guage for my truck
where can I purchase one for the dash of my 83 Chevy ,I would rather not go to all the trouble installing a used one if I can keep away from it by buying a new one, thx if you can help me out with this.
When you learn a thing a day you store up smart. |
07-02-2024, 10:55 PM | #2 |
Re: If I need a new Pressure guage for my truck
I am sure the truck vendors sell new gauges, but the face material may be plastic rather than metal...iirc the stock ones are metal?
"You can take the man out of PA, but you can't take PA out of the man" |
07-03-2024, 08:13 AM | #3 |
I know you are having issues with the reading , my 85 would at times peg the needle other times it would read zero . Then it started bouncing around I added a mechanical to confirm it wasn’t a mechanical problem . I then replaced the sender and the gauge reads normal again . Most aftermarket suppliers will have a replacement gauge . I kept the mech and installed the new switch in front over the timing chain cover
07-03-2024, 08:26 AM | #4 |
I replaced the sender when my gauge starting acting up, that fixed it.
07-03-2024, 06:00 PM | #5 | ||
I sure hope that is my probem as i have been told that to replace a pump is easier to take the motor out rather than take the H channel out to get the pan out..
07-04-2024, 09:33 AM | #6 |
Also if you have the wrong sending unit it could through the gage way off . I had that problem a couple of times on cars and trucks . Usually it was with the temp sender but I’ve had problems related to oil pressure senders too .
