Old 07-02-2024, 02:11 PM   #1
Rg500gamma
Poly Vs OEM Rubber mounts
A quickie regarding mounts . Who has used what and is a difference in the ride noticeable. I'm thinking the poly mounts are much stiffer and will last the test of time better than rubber oem. I'm trying to get the forum guys to shoot pros and cons of each setup .
Thanks all
Rg500gamma is offline   Reply With Quote
Old 07-02-2024, 04:24 PM   #2
LS short box
Re: Poly Vs OEM Rubber mounts
I run poly on my hot rod projects. No issues ride wise.
LS short box is offline   Reply With Quote
Old 07-02-2024, 04:46 PM   #3
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Poly Vs OEM Rubber mounts
i ran poly cab mounts on my 72 super 4x4 and i'll never do it again, it killed all the flex off road. in off camber situations-rocks- the entire cab was trying to flex and the headliner trim was popping and creaking. maybe on a street/racing truck it might be ok but you will feel any vibrations especially if you use poly trans and motor mounts.. just my 2 cents worth.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 07-02-2024, 05:00 PM   #4
PbFut
These trucks are not that quiet so a swap to poly will not likely be noticeable. As for longevity, probably not much longer than good quality rubber. Poly will disintegrate very quickly if not mixed with hardener correctly or poured while fresh so you need to monitor for signs of failure. I observed a failure of a batch of bushings made by a small vendor for the BMW aftermarket. They crumbled over a 3 or 4 year period. Many owners had to redo a rather involved task of removing a rear subframe a second time to replace.
PbFut is offline   Reply With Quote
Old 07-02-2024, 05:18 PM   #5
72c20customcamper
72c20customcamper's Avatar
I used rubber on both the trucks I replaced the cab and radiator mounts . Poly in my opinion is way too stiff . The rubber mounts are designed to absorb some shock . Poly in suspension is used because it doesn’t deform or deflect not something you want on a cab or body mount
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-02-2024, 05:52 PM   #6
PbFut
I was thinking motor mount for some reason. Cab mounts...you need the cushion. If it's a performance truck, and you stitch welded all the cab seams, you will probably get some benefit. But that's for the serious guys.
Old 07-03-2024, 12:42 AM   #7
truckster
truckster's Avatar
Rubber for the ride. And Wes at Classic Heartbeat sells some really good ones.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 07-03-2024, 07:28 AM   #8
Palf70Step is online now   Reply With Quote
Old 07-03-2024, 10:00 AM   #9
Joyridin
I have a set of poly mounts I will give you as soon as my rubber mounts arrive (they are on order). If you like a stiff ride, they are the way to go. They might work fine with a factory suspension, but mine is far from factory and rides a bit hard as it is. The poly mounts made the ride worse.
Just pay the shipping. They are black. They have been in about 1 month.
Joyridin is online now   Reply With Quote
Old 07-04-2024, 03:47 AM   #10
Luke87gt
Luke87gt's Avatar
Poly has absolutely no place on a street car/truck. Been there, tried that. Never again
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 07-04-2024, 10:24 AM   #11
tim_mc
tim_mc's Avatar
I currently have poly cab mounts and wish I would have went with rubber. If I switch them out I'll need to free up the front bolts as their heads were tack welded to the floor pan at the STL assembly plant.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 07-04-2024, 10:25 AM   #12
jerry moss
Born Psycho
jerry moss's Avatar
that's what i was trying to say above, but you made it sound better than i did.
jerry moss
Old 07-04-2024, 12:35 PM   #13
bnorth
Couldn't agree more. Did it in a previous build because racecar and it killed the street manners.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
