67 Grill Molding source
Does anyone have any first hand experience with these aftermarket grill moldings for a 67/68? I see a lot of places sell them but I don't know which is worth it.
My original ones have a couple of nicks / dents in them and with as much as I am spending on paint and already spent at Mar-K I don't want to use them if there is a quality set out there. Any insight greatly appreciated! |
![]() Join Date: Jan 2007
Re: 67 Grill Molding source
I just bought mine from gmc pauls. They are thin but if you’re careful they will turn out nicely.
Another option is to buy a steel set and have them chromed ![]() https://67-72chevytrucks.com/vboard/...d.php?t=851964
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
![]() Join Date: Nov 2001
68 bowtie that is NICE !!!
Is that your new trim that's thin on your pictured truck did your grill bowtie fit back in place like originally, my bowtie does not fit right with the new trim, the contor of the new trim is not the same as the original bowtie. I'll check tomorrow sometime to give the brand name. Just my opinion on the trim, came from CORVEX Last edited by NGN; 07-17-2024 at 09:18 AM. |
Thanks for the insight y'all!
It seems like Corvex is the only company making them, so you can probably buy them anywhere.
Be careful when you're installing those clips on the trim rings, the trim metal is thin and when you put the clips in place and twist you can crease the trim, it was a bit tight I used a plastic pry just lightly for the clips to twist in place, don't over twist or it will push up on the tin trim and make the outward dimples show on the trim. I made that mistake on the first to clips as I mentioned the clips were tight to twist in place. I would suggest starting with the bottom trim ring at the bottom of the ring first. My original bow tie does not fit in the trim properly, doesn't seem to have quite the same original contour. The Corvex headlight trim I did not used, shine and fit not to my liking.
I just put my grill together yesterday. The trim was from Corvex and is paper thin. Had a devil of a time getting the clips in and basically ruined one trim piece. That was due to not being able to get the clip to lock in place.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
Yeah they are a real pain!
I used the Corvex stuff. It fit fine. Yes the clips are pain. I used the Mar-K side trim. It was very nice. Fit perfect.
![]() Join Date: Mar 2011
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
