Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 07-09-2024, 09:02 PM   #1
docrock
docrock's Avatar
1941 to 46 Front fender sizes
Help identifying 1/2 ton fenders from 1 ton fenders.
I have a pair of fenders that if you measure to the ground at the location where the running board attaches and at the center of the axle from the fender lip to the ground, then subtract the two measurements, I have 17 inches. Is that right for a half ton fender?
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 11-13-2024, 07:54 PM   #2
docrock
docrock's Avatar
Re: 1941 to 46 Front fender sizes
I dont have my 42 green truck anymore so I dont have access to half ton fenders to verify what I have. I have figured out a way to measure them to tell the difference. the back edge of the front fender is bolted to the running board. that is the same on 1 ton and half ton. The size of the wheels dont matter. Even if you slammed it, it is still a measurement to the ground. Then if you measure at the center of the axle, from the ground to the fender edge. That is the second measurement. Subtract the two measurements and you end up with the half ton fender size. The one ton and larger will be a different measurement. Then when you are looking for parts you can use this info to help you find the right fender
Old 11-23-2024, 05:13 PM   #3
dennislbrooks
dennislbrooks's Avatar
Just info and pics. I used 1 1/2 ton fenders on my 42 and I fabricated my running boards because my wheel base is shorter on the s10 Blazer 2wd frame. Bed is custom made and shorter.
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
Old 11-24-2024, 12:29 AM   #4
docrock
docrock's Avatar
Looks cool. Thank you for sharing your project pictures
