Old 07-11-2024, 07:03 PM   #1
bautino95
any new direct fit parallel flow condensers for factory fit AC
Hi everyone. I recently got my truck back on the road and converted my AC system to r134. I recently had a post about high pressures with a low charge amount. anyways, I have a new aluminum A6 compressor, new lines, new dryer flushed evap. and condenser and calibrated my POA valve for r134 and reusing my expansion valve. Like I said in the previous post I was get high pressure with a low charge. So I thought it might be the expansion valve. but since I've evacuated the system again, I think I'm going to go ahead and replaced the condenser to a parallel flow to help get the pressures down.
I did a search about replacement condensers, but they all seem several years old. Does anyone know of a direct replacement parallel flow condenser for a factory AC setup. So far, I think I found one from Old Air Products that will fit with some brackets and supplied lines like this. but thought I should throw this out there. Thanks
https://www.oldairproducts.com/produ...enser-assembly
bautino95 is offline   Reply With Quote
