Grommet fresh air door
Need grommet for a/c door or picture can someone help
68 gmc cowl door Last edited by 68GMCjoe; 07-13-2024 at 10:17 AM. Reason: Added year and location |
![]() Join Date: Dec 1999
Re: Grommet fresh air door
Does this help:
https://www.lmctruck.com/mechanical/...and-components |
I didn't have ac on my 68 but to seal the lower vent doors I got a used semi truck tire inner tube from the local tire shop. They gave it to me. Just cut out a pattern and glued into place with contact cement glue. Zero money spent.
The grommet I’m looking for is for fresh air door for ac located between cowl and glove box
#5 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
Or are you asking about the vent in the passenger side kick panel, below & to the right of the glove box?
![]() Join Date: Jun 2022
Excerpt from the manual showing both, in case that helps
1970 C10 Custom longbed 350/350 |
A/c air shut-off valve in cowl pivots on grommet in cowl behind glove box .
That’s what I’m looking for LMC picture doesn’t show it |
This is what I need
20' Daredevil (Ret)
OK, gotcha. Not sure where you might find one. Sounds like you are describing the off-white nylon piece pictured below, to the left of the spring. Not a great pic of that grommet but it's what I was able to find.
That’s exactly what I need
20' Daredevil (Ret)
Just a guess, it might not be available. If not, look for a parts truck in a junkyard.
Looks like a part easy enough to fab with a nylon hunk from ACE?
#13 |
Would not call that a grommet. See it as a bushing for fresh air cowl flap. It is pictured. This is not reproduced as far as I know. I managed to get this one off the parts forum several years back for my A/C conversion. Become a member and ask in the parts forum. Maybe contact Classic Bowties. He has a lot of hard to get parts.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
