Old 07-17-2024, 09:05 PM   #1
Chilly178
Chilly178's Avatar
67 c10 rear drums loose
Hi on my c10 when I go to put the rear drums on the drum is very loose on the shoes. When I adjust the adjuster out enough for it to be snug the strut bar falls out because it is so loose. Any ideas?
Chilly178 is offline   Reply With Quote
Old 07-17-2024, 09:26 PM   #2
HO455
Post Whore
HO455's Avatar
Re: 67 c10 rear drums loose
Is this happening with or without the axle installed?
I don't see the piece in John's photo (Member #16. Thanks for the photo.) that the arrow is pointing to in the first photo in your photos. But maybe it's hidden.
RIP Bob Parks.
Old 07-17-2024, 10:52 PM   #3
Wrenchbender Ret
That cross Lever does not go between the shoes. There should be a lever connected to the rear shoe that swings down. The cross lever hooks into that lever & the slot on the other end goes to the front shoe.
You have a mismatch & missing parts. You need to get a manual with some good pictures & directions or get someone that has done these before to help you.
George
Wrenchbender Ret is offline   Reply With Quote
Old 07-18-2024, 07:29 AM   #4
yuccales
yuccales's Avatar
This has been shown before. Hope it helps out.
http://www.pbase.com/nufsed/drumbrake
yuccales is offline   Reply With Quote
Old 07-18-2024, 08:09 AM   #5
HO455
Post Whore
HO455's Avatar
That is a great write up on drum brakes.
RIP Bob Parks.
Old 07-18-2024, 08:49 AM   #6
Jason Banks
Jason Banks's Avatar
Without parking brake cables you probably don't need to even worry about installing the strut bar, since it is part of the parking brake system anyway.
The cable pulls on the parking brake shoe lever, that is put on the rear shoe, and pushed the strut forward into the front shoe, spreading it to engage the drum.
Jason Banks is offline   Reply With Quote
Old 07-18-2024, 09:16 AM   #7
Chilly178
Chilly178's Avatar
Thank you for all the replies everyone I will look at some literature. I have some experience with drum brakes but was confused on what was going on. I bought this truck with the shoes replaced like this. I will delete the strut bar for now and swap the shoes around just to get it done and on to the next thing. I removed the parking brake cable because it wasn't all there and was planning on running a automatic but I changed my mind. Eventually I will likely convert the rear to disk brakes down the line when the truck is on the road.
Old 07-18-2024, 11:41 AM   #8
geezer#99
geezer#99's Avatar
Originally Posted by Chilly178 View Post
I removed the parking brake cable because it wasn't all there and was planning on running an automatic but I changed my mind. Eventually I will likely convert the rear to disk brakes down the line when the truck is on the road.
The parking brake isn’t just for parking.
It’s the emergency brake. In case you loose all your hydraulic brakes the park brake will get you stopped.
Old 07-18-2024, 01:50 PM   #9
Rust_never_sleeps
Rust_never_sleeps's Avatar
I had heard to never touch the second side of a working pair until you've got the first one working. That way you can just walk around and see what the working one is supposed to look like. Kinda like spark plugs.
Then again, if someone's already gone into both, you have to go back to pix on the interwebs
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 07-18-2024, 05:20 PM   #10
RustyPile
RustyPile's Avatar
The following may not apply to all states. State Safety Inspection requires the vehicle to have a working emergency/parking brake. Park position on an automatic transmission does not meet that requirement.
An emergency brake is fully mechanical. It functions totally separate from the hydraulic braking system. As your vehicle's brakes now operate, in the event of a total hydraulic failure, you have NO brakes.
RustyPile is offline   Reply With Quote
