Old 07-22-2024, 09:20 PM   #1
gordyzx9r
Junior Member
gordyzx9r's Avatar
Box, Tool Stowage Hinge Placement?
I'm in the process of putting the truck back together after body and paint.
The original three hinges were in really rough shape and the body shop cut them off the truck without knowing any better...so I had to source three used ones.
Are they supposed to go on like this? With that big of a gap towards the bottom of the door?
When we put it on the truck and closed the door, the door was sticking out about a 1/4".
Can someone take a pic of theirs from the side showing how their hinges are fitting on the door please?
I was thinking the hinges might be bent, but they're all identical.
Edit: Yes, we removed the lock mechanism and opening...got tired of trying to source it and figured we're not gonna keep anything in there that needs to be locked up anyways.
gordyzx9r is offline   Reply With Quote
Old 07-22-2024, 09:50 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Box, Tool Stowage Hinge Placement?
I think they go the other way.
I can check mine tomorrow in the Daylight.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 07-23-2024, 11:42 AM   #3
gordyzx9r
Junior Member
gordyzx9r's Avatar
Thanks. Not sure how it could...but maybe.
I've been trying to look at different images in old posts here.
https://67-72chevytrucks.com/vboard/...d.php?t=539198
A couple of them look like the hinges are flush with all the bends in the door. Some look like mine. Others look like they run a seal over the hinges, and others under it.
And one looks like they mounted the hinges to the the metal of the truck, then slid the storage compartment in or they cut out the area for the hinges in the storage compartment which doesn't look right and I'm not about to cut this thing up.
Old 07-23-2024, 02:31 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
Lemme see if I can find the pics of mine.
Tyler
57taskforce is online now   Reply With Quote
Old 07-23-2024, 05:45 PM   #5
Getter-Done
It had been a while since I looked at them.
Yes, You do have the hinges on the correct way.
So, I am waiting on my pictures to go thru the Clou d to my email
I will post them later.
Maybe Tyler will find his.
I have more Pictures buried in my phone.
84 Chevy K-20
Old 07-23-2024, 07:31 PM   #6
57taskforce
All about them K’s
This is the best picture I’ve got readily available. Yours look right to me.
Tyler
Old 07-23-2024, 07:44 PM   #7
Getter-Done
hope these help .
I can get better pictures if needed.
84 Chevy K-20
Old 07-23-2024, 09:29 PM   #8
gordyzx9r
Junior Member
gordyzx9r's Avatar
Attachment 2380606
Attachment 2380607
Attachment 2380608
hope these help .
Yeah, that does look similar to what I have. We just can't seem to get the door to seat somewhat flush when closed.
Old 07-23-2024, 10:01 PM   #9
Getter-Done
It may have something to do with the under bracing.
Here is a Thread of a picture of the original stuff.
Which IMHO needs to be improved with Drain holes.
Link: https://67-72chevytrucks.com/vboard/...box+fender+www
84 Chevy K-20
