07-24-2024, 11:29 AM | #1 |
Does anyone know the brake line sizes for a 76 C10?
Hello all, I'm looking for the size of the my rear brake line the one that runs along the passenger side fuel tank.
Mine line isn't leaking but there's a really rusty spot that's pretty deeply pitted, bad enough that I don't really feel safe running it. I could just buy a premade line but was thinking maybe just make my own but have no clue what size line or fittings to buy.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
07-25-2024, 10:41 PM | #2 |
Re: Does anyone know the brake line sizes for a 76 C10?
I'm currently working on replacing all the lines on my 81 while I have easy access. Not sure if it's the same as your 76, but on my 81 the rear line from the proportioning valve to the rear axle hose is 1/4" line. So is the line from the master to the prop valve. The front lines are all 3/16". I'm not sure what the lines are on the rear axle itself as I haven't pulled those off yet
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-25-2024, 10:46 PM | #3 |
All about them K’s
Fronts should be 3/16, front to rear should be 1/4 all the way and thru the rear soft line, back to 3/16 from the rear soft line distribution block to each wheel cylinder across the rear axle…
I would suggest getting NiCop brake line for the splice. It doesn’t rust and it’s really easy to work with.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
08-03-2024, 12:32 PM | #4 |
Sorry for the late reply but I ordered the 1/4 nicop line worked out great got it installed last week thanks again guys.
