01-13-2004, 07:56 PM | #1 |
Dash Question ?
Pulled a standard gauge dash panel (speedo, fuel, amp, oil, and temp, no tach ) from a "plain jane" run of the mill 71 2wd LWB. On the back of the panel for the lamp sockets were the usual black twist in sockets except for one that was different. It is the same style but off-white in color and has a metal electrical terminal molded to it. Never seen one before. Anyone have an idea? Looks like it would be ideal to use as a grounding point with the bulb installed and a wire terminal attached to the metal dash or cab. Any input is appreciated. Thanks
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
01-13-2004, 07:59 PM | #2 |
That is where the fibre optic cable hooks to for you column indicator light.
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
01-13-2004, 08:00 PM | #3 |
i got a extra fiber optic cable....
10.00 shipped if you need one |
01-13-2004, 08:12 PM | #4 |
pickupman, Thanks for the reply. Guess it is something not needed on my 71 4x4 4-spd. Are they hard to come by? Like I said I've never seen one before. Also guess it would not work to use as a ground / bonding strap point. Might cause a bit of "arcin' and sparkin' " which is not a good thing.
Thanks for the offer rage but have no need for the fiber optic on my floort shift column.
01-13-2004, 08:36 PM | #5 |
The socket is not hard to come by, but the cable is hard to find a good one. Good deal from ragnrat if anyone needs one
01-14-2004, 12:24 AM | #6 |
its all about the +6 inches
The port will not ground anything out if you were to ground it...the cable just transmits the light from the bulb up the coilumn.
