LMC delivery...
...success! Tuesday last week, I ordered the early windshield trim. Received the shipment today and initially was worried stuff would be damaged as the box was open. However what I found inside was a relief as the trim was in its own box, taped in so it wouldn't move around and was packed into the outer box pretty good. This must have been sitting on a shelf for a very long time as the outer box "top" was caked thick with dirt and dust. Trim looks to be in good condition. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: LMC delivery...
Let us know about its fit please!!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Re: LMC delivery...
yes!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Re: LMC delivery...
Install did not go well. The culprit is the gasket from LMC. The trim wasn't really the problem this time around. This glass has already been installed successfully with a precision gasket but the (late model) trim popped out and so it was a failed install. This purchase of trim+gasket from LMC was an attempt to get past the difficulty of installing the late trim (that with a shallow anchor) on my truck. I bought the early trim (that with a 5/8 inch anchor down into the gasket) and matching gasket for the installer this time to try and make it easier and successful. With the LMC gasket, the installers could not get the glass even close to going in the hole. They tried twice. Once roping from the top first and a second time roping from the bottom first. Both attempts came up over an inch short of being able to get the thing in the truck. That is, the glass needed to move an additional inch after being fully seated on either the top or bottom. They're gonna give it another shot soon with a Precision branded gasket. Right now I'm very disappointed. -Kevin
Re: LMC delivery...
Installers came back today for the 4th and final time. Glass with trim is in. The LMC trim fit fine. The LMC gasket on the other hand would not work at all. The installers brought a Precision gasket which worked fine with the trim. Verdict: LMC trim good. LMC gasket is not good. -Kevin
All about them K’s
![]() Join Date: Jun 2014
Re: LMC delivery...
That’s good to know, I know I’m the past the aftermarket trim has been total junk. Glad they’ve made it better.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's |
