Old 07-28-2024, 10:44 AM   #1
64stpside
This might need to be a sticky on disc brake conversions
**I say this should be a sticky as I think this would help a lot of folks pulling their hair out trying to fix this issue**
So i just got done doing a 4 wheel power disc conversion on my 64 c10 with a wilwood adj proportioning valve for the rear.
-bench bleed master cyl
-bleed brakes using the 2 person method in this order: lft rear (has longest amount of brake line), rt rear, rt front, lft front
-Can't get a good pedal until it's about 3 in off the floor.
Of course,I layed in bed and can't sleep try to figure out what i did wrong (as most of us do when we can't the solution to our problem and have to quit for the day....lol)
I found this on youtube this morning. The guy said most disc brake kits don't say a thing about doing this, I can tell you the auto city classic stuff doesn't.
YOU HAVE TO DRILL A NEW BRAKE PUSH ROD MOUNTING HOLE 1 IN
LOWER FROM THE ORIGINAL MOUNTING HOLE.
here's the link what he shows the difference in pedal travel:
https://www.youtube.com/watch?v=iGVNJ87szt0
64stpside is offline   Reply With Quote
