Old 01-13-2004, 08:12 PM   #1
Porkchop
Porkchop's Avatar
3/4 ton front and rear
I really need to get rid of some parts off my 69. I have the 3/4 ton open differential rearend (4.11) POSSIBLY with the leaf springs, 3/4 front crossmember drum to drum, and five steel eight lug rims with tires....all for $150. I just want it gone. This is a very low price. All of the parts are operational and worked fine when I was driving the truck----but the last time I drove it was 2 years ago.
thanks
brad
Porkchop is offline   Reply With Quote
Old 01-13-2004, 09:46 PM   #2
69k5
is the rear end an eaton? if it is would yuou sell just the 36d member.
69k5
69k5 is offline   Reply With Quote
Old 01-13-2004, 09:56 PM   #3
Porkchop
Porkchop's Avatar
What is the 36d member? Sorry, I have never heard that term.
Old 01-13-2004, 10:08 PM   #4
69k5
if its an eaton the pumpkin (middle) looks like a big basketball. the gears unbolt and come out of the front. on the front side of the rear end you will see where it unbolts. the back side has a regular cover on it for the fluid. you can see some pics of one in my webshots. the back side in the eaton album and the front side you can kinda see in the parts album.
69k5
Old 01-14-2004, 02:02 PM   #5
Porkchop
Porkchop's Avatar
I looked at your webshots. I don't think I have an eaton. Mine is shaped funny. Someone on here told me what it was once, but I forgot.
Anyways, I want to sell it as one piece. I will seperate the different parts that I metioned, but I don't want to part out each individual part.
thanks
brad
Old 01-14-2004, 04:10 PM   #6
69k5
no problem. just wanted to ask. it si probably a 14 bolt or dana 60 if its not an eaton. check out www.coloradok5.com and they have an axel id in their tech section if you need some help. also www.alaskaoffroad has one as well that includes the eaton.
69k5
