Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 07-29-2024, 02:44 PM   #1
Chaparralman1974
Chaparralman1974's Avatar
Paint Mixing for Idiots
Ok, I am going to apologize in advance for a dumb question....but math was never a strong point with me, so please be gentle. :-)
I am getting ready to apply a seal coat of epoxy primer to my project. I am using the eastwood epoxy primer which is a 1:1 mix ratio of primer to activator.....easy enough. Now, according Eastwood, I need to reduce this by 20% with a urethane reducer in order to use it as a seal coat. How do I do this on a mixing cup? I have a boat load of these.
Math sucks....plain and simple. In high school I dropped out of geometry because it was dumb and I would never ever need to know squat about angles. Well, I ended up joining the Marines and they made me a mortarman.....I guess Mr. Tuttle (geometry dick in HS) was right after all.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 07-29-2024, 07:59 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Paint Mixing for Idiots
I'd go by the oz. marking on the cup... multiply however many oz you mix by .20...that'll be how much reducer you need
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-29-2024, 11:04 PM   #3
Getter-Done
Getter-Done's Avatar
I total understand this.
The math thing.
I almost failed Algebra in the 80's .
My grandpa helped me through this issue.
Stay with me on this story.
I was a Knucklehead back then. (and still can be)
I would ask the math teacher,
Why do I need to know A+B=C ?
She said it is a Formula you apply to figure things out.
Years later I Totally Understand.
Grandpa sat me down on the back stoop of My Grandparent's home.
Then He proceeded to show me WHY.
At 17 years old I didn't need that.
Now years later I am a Machinist.
I not only use Trigonometry.
I know how to spell it.
Now let's get serious.
When you are getting ready to mix the paint you can give me a Call.
You have to use the KISS philosophy.
Just use the single digit stuff.
Think of this as Money.
If you have 50 cents of Primer./ 5 ounces of primer
Then you add 50 cents of activator. / 5 ounces of activator
This mix is = to 100%
You have a 1:1 ratio.
Then add 20 cents / 2 ounces of Reducer.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 07-30-2024, 10:59 AM   #4
Chaparralman1974
Yeah, math has always been a challenge for me. It can be pretty embarrassing, but for some reason I just have always had a difficult time with numbers. The only exception is fractions. I have always been good at those....maybe due to my use of a tape measure for so many years doing concrete work. Thankfully, my wife is a numbers whiz kid so she handles all that stuff.
Ok, I think that I will try to just use 20% of the total after I mix the primer and the catalyst like Greg mentioned.
Thanks fellas!
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 08-04-2024, 09:11 PM   #5
hugger6933
If you do fractions 1/5 reducer. If improves flow from the gun . I add a little MR186 to all my primers and have for many many years [Thats Omni numbers for the non PPG people] It just a splash to like I said help flow and reduce the "pebbled" look that some primers might give off depending on the primer. Good luck Happy sanding [although if your doing sealer your close to done with the sanding. Thanks for your service. Jim
hugger6933 is offline   Reply With Quote
Old 08-05-2024, 08:09 AM   #6
Chaparralman1974
Thank you Jim!
I am getting closer now. The only body work left on the truck is the tailgate now. I am hoping to get everything sanded and painted by Halloween, but we will see. :-)
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 08-07-2024, 10:00 PM   #7
kwmech
20 percent is a division of 5. So total ounces divided by 5. how's that for simple
Old 08-08-2024, 09:06 AM   #8
Chaparralman1974
Thanks! I will try it. :-)
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
