Old 08-01-2024, 06:34 PM   #1
54blackhornet
54blackhornet's Avatar
SM 465 Shift Leaver ?
Can someone please tell me how to remove the shifter assembly ? I have heard that it is the easiest way to refill the fluid after a change.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 08-01-2024, 06:44 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: SM 465 Shift Leaver ?
Put it in neutral and push down and turn at the same time on the collar assembly assembly at the base of the shifter where it goes into the transmission. It will only turn one way and I believe it’s to the right to remove but it’s been a little bit since I pulled one of my shifters. Once you get the collar rotated pull the shifter straight up. There will probably be a little oil on the portion of the shifter that is in the top of the transmission.
Tyler
57taskforce is offline   Reply With Quote
Old 08-01-2024, 09:26 PM   #3
Jason Banks
Jason Banks's Avatar
Here you go:
https://youtu.be/IZj0AxtYPGE?t=248
Jason Banks is offline   Reply With Quote
Old 08-02-2024, 02:19 AM   #4
mr48chev
mr48chev's Avatar
It's not usually that easy though you have to have some strong thumbs.
My ongoing truck projects:
Old 08-02-2024, 02:29 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
General Motors used to have a Special Tool, that had a big T handle and a steel wrench with a cut out for the shift lever. Push down and twist, and the tin collar pops up. I made one, years ago, by cutting a 1/2'' wide cut out of one side of a 2 x 4 . Worked the same way, but it broke eventually. Still easier than using your thumb and forefinger. In my Twenties I didn't need no stinkin' Special Tool, but I can't say that now.
Old 08-02-2024, 10:36 AM   #6
54blackhornet
Thanks everyone ! I did this years ago when I didn’t feel like crawling underneath the truck. It’s not the fall that’s bad, it’s getting back up !
71 C-20
07 Magnum RT AWD
Old 08-02-2024, 12:50 PM   #7
Keith Seymore
Keith Seymore's Avatar
We used channel locks on the assembly line.
https://youtu.be/8yJuHd8CROs (approx 3 min mark)
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-02-2024, 06:30 PM   #8
'68OrangeSunshine
K
General Motors Technicians not using Special Tool J-8109?
I'm shocked!
