Old Today, 01:03 AM   #1
canadaboy25
canadaboy25's Avatar
82 K2500 6.2 Diesel Air Conditioning Ideas
Hi all, browsing through the site I see a ton of threads about AC, but not much regarding diesels.
I've been fighting with the AC in this truck and losing, so I'm looking for ideas. The truck is a 1982 K2500 with a 6.2 diesel.
First, a description of the system. Originally the truck had no air and a 6.2 with the factory v-belt setup. I tore all of the air components out of a donor truck, modified the firewall, and installed it all in my truck. I had to fabricate my own compressor bracketry to make it work with the diesel. This setup sort of worked but I was constantly springing leaks. The last thing I did was buy a new R4 compressor and the system worked "okayish" for a bit.
A few years later, I swapped the v-belt system to a serpentine system from a 93 truck. This relocated the compressor to the top on the passenger side. So I had to install the compressor on the other side of the engine. The lines on the condenser also had to be bent straight sideways to clear the radiator. I blew all the oil out of the evaporator and condenser, and installed a new orifice tube. I also installed the compressor from the 93 since it had the serpentine pulley.
I charged the system up and after a few seconds, the shaft seal on the compressor blew out. So I swapped the clutch over to the compressor I had bought previously and recharged the system. I cannot get any cool air at all, no matter how much refrigerant I use. The low side is always way too high.
I am tired of screwing around with this. I have looked at aftermarket kits, but have seen mixed reviews on them. The other issue is that the kits all seem to come with a sanden compressor. This won't work with my serpentine system on the diesel since the brackets are two large cast iron pieces which also mount the vacuum pump.
Does anyone have any ideas on how to go about fixing this mess? The system is such a cobble of different parts and years, that buying new parts is a crap shoot. I am open to an aftermarket unit so long as I do not lose my glove box, and the compressor will mount cleanly to a 6.2 diesel with a serpentine setup. I would like to just buy a bunch of new stock parts, but I cannot seem to figure out the combination of years to buy for to make everything work together.
Knowing how much oil and refrigerant to add is also difficult since the truck is an 82 but the engine and compressor setup is a 93.
I'd like to hear your thoughts/suggestions
canadaboy25 is offline   Reply With Quote
