Old 08-04-2024, 01:31 AM   #1
howzzzit
howzzzit's Avatar
Truck rallys and disc brakes problems
I know there are several posts about this subject, but here we go again. I have a set of 15x8 truck rallys with 4 inch backspacing. They will not mount over the original brake calipers. Truck is original and original ride height with no modifications. It's been stated this type of wheel is compatible with disc brakes as long as they aren't larger aftermarket calipers. I have a 72 C10 with disc front/drum rear. What gives? I haven't tried them on the rear drums, but if they won't fit the front they are useless to me. Bought these at a swap meet and a lesson learned. Any thoughts? (other than I'm screwed) Thanks
One thing I notice is a slight inward taper of the rim toward the hub. Normal?
howzzzit is offline   Reply With Quote
Old 08-04-2024, 03:49 AM   #2
PowerdbyChevy79
PowerdbyChevy79's Avatar
Re: Truck rallys and disc brakes problems
What is keeping them from fitting? 15x8 rallys should fit with no problem on a 72 c10. Do you have any pics of the wheels?
1966 C10 Mary
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 08-04-2024, 11:27 AM   #3
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Truck rallys and disc brakes problems
are you sure they are truck rallys, factory truck rallys weren't available until a few years after disc brakes became standard equipment on all GM light duty trucks. post some pics so we can see where the problem is.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 08-04-2024, 02:28 PM   #4
howzzzit
howzzzit's Avatar
Thanks. I'll send pics asap. Won't go through it says a security token missing. That's a new one.
Old 08-04-2024, 03:27 PM   #5
dmjlambert
dmjlambert's Avatar
I have encountered that and fixed it by reducing the picture size to 2000 pixels wide and add the pictures one at a time. You can still compose a post with 5 pictures, but just upload them one at a time.
dmjlambert is online now   Reply With Quote
Old 08-04-2024, 03:48 PM   #6
howzzzit
howzzzit's Avatar
Thanks DJ. It worked.
Old 08-04-2024, 04:16 PM   #7
Rust_never_sleeps
Rust_never_sleeps's Avatar
I have no insights to offer, but maybe slap some painter's tape on the inside of the rim to show you where it's rubbing(without marking the metal). Maybe a blobby weld, or something you can clean up.
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 08-04-2024, 09:30 PM   #8
too much stuff
Roadtrip!
too much stuff's Avatar
They should fit without issue. Are they stamped 15x8jj or something similar? My only thought is maybe aftermarket but even those SHOULD fit.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 08-04-2024, 11:27 PM   #9
Smitty
Smitty's Avatar
Can't remember for sure. But when I went with the 115x8's on my '71 the issue wasn't with the calipers. But the problem was because of the dropped spindles that were interfering. Had to grind a small amount of material off to get the needed clearance. So take a look at this area instead of the calipers. It's been 20+ years ago, so can't remember exactly where the rub was. But in that era I think this was somewhat a problem often encountered. Best of luck.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is online now   Reply With Quote
Old 08-05-2024, 12:46 AM   #10
howzzzit
howzzzit's Avatar
Smitty it's stock suspension. I'm gonna mess with it tomorrow or the next day. Been too hot. Thanks for the reply.
Old 08-05-2024, 01:16 AM   #11
PowerdbyChevy79
Those look like regular rallys... the should fit with no issues … especially with stock suspension.
1966 C10 Mary
Old 08-05-2024, 09:19 AM   #12
SCOTI
SCOTI's Avatar
Post an image of the truck as well as one of the front suspension & spindle.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-05-2024, 04:17 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I had some raised areas on the casting line on the backs of the disc brake calipers on my '72. I had to take a grinder and smooth out the backs of the calipers for them to not rub on the 15x8 slot mags I used up front.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-05-2024, 06:31 PM   #14
jaros44sr
jaros44sr's Avatar
image by [url=https://www.flickr.com/photos/97391199@N06
If I couldn’t run my 6lug slotted steel wheels,I’d be hard pressed to choose something else
No problem bolting them on with suspension or calipers, but it’s 4WD………
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-06-2024, 12:05 PM   #15
SCOTI
SCOTI's Avatar
6-lug car 'Rallys' are definitely aftermarket vs an OE 15x8" truck 'Rally'.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-06-2024, 02:03 PM   #16
howzzzit
howzzzit's Avatar
OK I'm a dumb a__. The rims weren't hitting the calipers like I first thought. The wheels Have been powder coated. In fact, twice. Wrong color the first time. Anyway the problem was the wheel center. Just enough powder coat buildup to keep the rim from seating. I used a drum sander on all four wheels and now they all fit perfectly. Didn't take off much, but it worked. Thanks for everyone's replies. Maybe this will help somebody down the line. I can now sleep tonight.
Old 08-06-2024, 04:27 PM   #17
68Gold/white
Festus, if you rode a horse like everyone else, instead of that mule, you might not have these problems!!!!!!
68Gold/white is offline   Reply With Quote
Old 08-06-2024, 05:02 PM   #18
jerry moss
Born Psycho
jerry moss's Avatar
jerry moss
