![]() ![]() Join Date: Jan 2005
5k Tach Cluster
Here are the details on this cluster:
Tach - Brand new reproduction Fuel, Temp, Oil & Battery Gauges - These are nice OE gauges that have been bench-tested. They all function correctly. Speedometer - This is a nice OE unit. Tested by spinning it with a servo motor at precisely 1001 RPM, and it read 60mph (60mph is perfect). Input shaft lubricated and odometer set back to zero. Front Tin - OE - Factory-style formed opening added for the tach. Video Back Tin - OE - Tach hole added using a CNC router based on a pattern made from a factory tach tin. Video Lens -OE - Dummy tach markings removed, and die-cut decals applied for the 5k tach. The lens is nice, and it has very little in the way of swirl marks or scratches. Video Bezel - Reproduction 69-72 style from Auto Metal Direct. NOTE: CAN BE SWAPPED OUT FOR A 67-68 STYLE IF YOU WANT Printed Circuit - Brand new reproduction Bulbs - Tested good $375 + shipping Zelle, Venmo, CashApp or money order only. Send me a PM or email me at dummyfillernecks@gmail.com if you have any questions. Last edited by pjmoreland; Today at 12:50 PM. |
Re: Tach Cluster
More photos
Re: Tach Cluster
Light testing
Re: Tach Cluster
Fuel gauge testing
Re: Tach Cluster
Temperature gauge testing
Re: Tach Cluster
Battery and oil pressure gauges
Re: Tach Cluster
Speedometer
