Old 08-12-2024, 08:57 AM   #1
gordyzx9r
Junior Member
gordyzx9r's Avatar
What are these plugs/wires for?
I can't seem to find these in the wiring diagram...
The one on the passenger side looks like it broke at the end to wherever it's supposed to go and when I pulled it apart it looked like it had a glass fuse that rusted and caused it to break. There is an identical plug/wire on the driver side.
1970 C10 but it's not original and had lots of DIY mods over the years before we got it and a mad scientist did all the "wiring".
gordyzx9r is offline   Reply With Quote
Old 08-12-2024, 09:17 AM   #2
PbFut
Re: What are these plugs/wires for?
Battery meter
PbFut is offline   Reply With Quote
Old 08-12-2024, 09:21 AM   #3
gordyzx9r
Junior Member
gordyzx9r's Avatar
Originally Posted by PbFut View Post
Battery meter
This is going to the voltage gauge? Why the two plugs/fuses on both sides of the truck?
Old 08-12-2024, 09:30 AM   #4
72c20customcamper
72c20customcamper's Avatar
Both are used for the amp meter . Takes the mini glass fuse
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-12-2024, 09:35 AM   #5
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
It's for an original Ammeter not Voltage meter. The Ammeter senses the difference in voltage on both ends of the circuit. If you're truck still has an Ammeter then you'll need both fuses. If your truck has been retrofitted with a Voltage meter then this circuit should no longer be hooked up or needed.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 08-12-2024, 10:18 AM   #6
RichardJ
Both use a 4 Amp fuse for the Battery Gauge (Ammeter). They both go directly to the gauge and nowhere else.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 08-12-2024, 10:37 AM   #7
Wrenchbender Ret
If it is corroded or you can't get the broken fuse out, you can replace it with a universal inline fuse holder & a 4 amp fuse.
George
Wrenchbender Ret is offline   Reply With Quote
Old 08-12-2024, 10:43 AM   #8
jaros44sr
jaros44sr's Avatar
I’d soak it for a few days in WD-40, then grab the remaining metal with smallest needle nose pliers ya got in your toolbox, don’t destroy the rubber boot
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-12-2024, 12:30 PM   #9
Rust_never_sleeps
Rust_never_sleeps's Avatar
In case it's not blatantly obvious, these are the short type. P/n is SFE-4
I couldn't find them locally and had to order them off the River.
Near as I can tell, that janky looking plastic tape on the bundle is original
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 08-12-2024, 04:55 PM   #10
gordyzx9r
Junior Member
gordyzx9r's Avatar
Thank you everyone, it does have the stock ammeter in it but never worked...now I know why.
But we do have an aftermarket set of gauges for oil press, voltage, and water temp so we're just going with that and deleting everything else...
Thank you.
Old 08-13-2024, 12:32 AM   #11
HO455
Post Whore
HO455's Avatar
I couldn't fine them locally and had to order them off the River.
Inside that janky bundle of tape lies the main splice of the harness.
RIP Bob Parks.
Old 08-14-2024, 07:29 AM   #12
BRL
BRL's Avatar
Originally Posted by 67 twins View Post
...If your truck has been retrofitted with a Voltage meter then this circuit should no longer be hooked up or needed.
I just wanted to take a second to let you people know how much I appreciate this forum.
I have both the plugs and fuses and I had no idea what they did so I left the wire connected forever even though I installed a voltmeter long ago.
Good job you guys!
BRL is offline   Reply With Quote
