Old 08-15-2024, 11:25 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Brake fluid trick for leaky steering box?
I had my steering box rebuilt by reputable. It sat around a few years, something went wrong, perhaps the pitman seal just dried up. Man it bugs me, but really, at this point, I just don't like the idea of messing with it. I think you have to pull the skirt off, risk paint damage etc. So at this point, at least the fluid is always fresh.
A well-seasoned reputable guy tuned up my carb. today for its "500 mile check-up" following a restoration. Man, he dialed it in to, best its ever run. Anyway, he says put a splash of brake fluid in the PS reservoir, not too much, perhaps an ounce.
He didn't believe it himself until his brother did it "for steering box only". Fixed the problem and never to be heard from again, apparently it swells up the seal for you. I wouldn't expect any damage to the finish, though, I don't know, I suppose a guy doesn't have to use DOT3, I should ask him, but I'm mostly sure he meant DOT3. On that note, I hear silicone swells seals too. Hmm.
What do you think?
Speak of, anyone know off hand how much you're supposed to fill a remote PS reservoir? I've always figured about 1/2-3/4" from its top. Doesn't seem a big deal, so long as it's attended to and doesn't spill. Happen to know what the fluid capacity is, box, hoses, reservoir and pump?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-15-2024, 11:46 PM   #2
GSP7
GSP7's Avatar
Re: Brake fluid trick for leaky steering box?
Dont do it
use 1 oz of Vitamin E
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 08-16-2024, 12:16 AM   #3
Sheepdip
Sheepdip's Avatar
That's an old automatic transmission trick also, don't know that I'd do it to a fresh trans build, but more along trying to limp a high mileage one along.
I have used Lucas P/S Stop Leak fluid with success until I got a new pump/box ordered then installed a few months down the road.
A patch is just that.. a patch, gets you out of a jam or buys a little more time.
Sheepdip is offline   Reply With Quote
Old 08-16-2024, 08:36 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I also used the Lucas stop leak and it worked for me....
Leon
Old 08-16-2024, 11:03 PM   #5
dmjlambert
dmjlambert's Avatar
Stop leak didn't help mine. I recommend just replace the seals. It is not a bad job to just do. There is no skirt to pull off, not on the truck anyway. And it's not in an area of the truck that could give you paint damage. I found it easier with driver side inner fender removed. Remove the steering gear, put it on a workbench, and change the seals. https://67-72chevytrucks.com/vboard/...d.php?t=619634
dmjlambert is offline   Reply With Quote
Old 08-18-2024, 12:09 AM   #6
71CHEVYSHORTBED402
The inner fender is what I meant by skirt. I hear you, but it would be nice to avoid it. I hear stop leak buys only a year, perhaps that's just the radiator.
Originally Posted by GSP7 View Post
Dont do it
Interesting, the homoeopathic approach. Ever try that or know someone that did? I may have to try that, at worst the system won't care, I suppose.
Tony
Old 08-19-2024, 10:58 AM   #7
Accelo
Accelo's Avatar
I have repaired many a transmission with the "stop leak" and or "Trans repair" additive added to them. The seals eventually soften enough to turn into what looks like sponge rubber and fail.
Maybe it's a stopgap for a needed seal replacement? I don't know, but I know it will eventually return and need repair.
Accelo is offline   Reply With Quote
Old 08-19-2024, 03:06 PM   #8
Rust_never_sleeps
Rust_never_sleeps's Avatar
Pretty sure using silicon brake fluid has the same effect: swells them and degrades them at the same time.
Some people swear by Mystery Oil, but I feel it's also a stopgap measure
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 08-21-2024, 04:29 PM   #9
j_cst_10
j_cst_10's Avatar
It’s very inexpensive and not difficult to reseal the box. You can do it with the steering box still attached to the frame. There are some write ups on it here, it’s easy. I’ve done several since they all seem to leak.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 08-25-2024, 01:24 AM   #10
71CHEVYSHORTBED402
No kidding, I didn't consider it could be done without pulling the box. I'll have to look into it.
I've decided to pass on any tricks or additives, you guys talked me out of it thanks. Might fix the box for a stint, then again, seems it might blow a seal in a perfectly good pump.
Tony
Old 08-25-2024, 01:32 AM   #11
71CHEVYSHORTBED402
Tony
