![]() Join Date: Jul 2024
Rear Outer Wheel Housing
Any suggestions on rear outer wheel housings? I need both sides. Had anyone tried to use the wheel housing section off of a inner bed panel for a fleetside? I'm not sure if the wheel opening is the same as a pick up.
Re: Rear Outer Wheel Housing
Almost 30 years ago, when i had my 71 GMC K10 Suburban rebuilt i supplied the body shop with a rust free fleetside box. They said it was a little different but still used it to repair all the rust. Which wasn't all that bad.
If the opening is the same, I'm thinking about getting the inner fleet side patch panel and cutting the wheel housing section off. I know there will be some fabrication work involved to attach it to inner housing.
| Bookmarks |
