Old 08-17-2024, 07:39 AM   #1
dennislbrooks
dennislbrooks's Avatar
Electric Wiper on 59 GMC Fleet
I used LMCs electric wiper conversion to replace the oe vacuum setup. My 59 GMC should be like at least the 58 if not near all 47-59. It is maybe somewhat a universal kit for those years. It has adjustments.
I like the 2-speed kit and LMC had good pricing. I did have to remove both existing arm bushings that mounted to the stock motor arm. (I did in truck) Then you use all the bushing supplied on new motor arm, It is a good idea to fit the 2 allen wrenches to the arm adjustment. If they do not point down when mounted, rotate before you do the initial install. Remove wiper blade arms beforehand also. They are near the last to put back on.
My stock black plastic knob would not work as it is hex and the switch is half-moon but they do send a chromed stock like brass knob that I will blast and paint black sometime.
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
