Old 08-19-2024, 03:40 PM   #1
jaye deluxe
frame rail width
Anybody know the difference (if any) in the width between the frame rails of a 1968 C20 and 1968 C10 ? I'm looking to buy a hidden trailer receiver hitch, behind the license plate. Some manufacturers say it's a different width and others say their hitch fits both. Thanks !!!
jaye deluxe is offline   Reply With Quote
Old 08-19-2024, 09:06 PM   #2
HO455
Post Whore
HO455's Avatar
Re: frame rail width
There may be a difference in the hitches between K-models and 2wd trucks as I believe they have different bumper brackets. That may interfere with the hitch mounting. But I don't believe there is a difference between a 10 and a 20 frame in the same model.
What model of truck are you looking to put the hitch on?
RIP Bob Parks.
Old 08-19-2024, 09:09 PM   #3
RustyPile
RustyPile's Avatar
You didn't say what truck (C/10 or C/20), so do this.. Measure your frame and then measure the hitch you're looking at.. Saves the time and trouble of having everybody running out and taking frame measurements...
RustyPile is offline   Reply With Quote
Old 08-19-2024, 10:15 PM   #4
jaye deluxe
Sorry guys, I have a C20. The hitches I'm looking at are all online, no way to actually measure. I even called the manufacturer to get a measurement, but they couldn't provide that info. The hitch for the C10 is $150 less than the C20 hitch, and all I could find out is the C20 is narrower. Talking to different manufacturers is just making this more confusing. I thought I could get some clearer info from you guys !!!
Old 08-19-2024, 10:16 PM   #5
jaye deluxe
Sorry, I have a 1968 C20
Old 08-19-2024, 10:22 PM   #6
MS66
MS66's Avatar
How wide is your C20 frame at the mounting point? How far does the hitch sit into the frame rails from the edge of the frame inward?
MS66 is offline   Reply With Quote
Old 08-19-2024, 10:33 PM   #7
RustyPile
RustyPile's Avatar
That 's just one of the pitfalls involved in online shopping. I buy very little online products.. I want to see and touch what I'm buying.. . Do you have major brand auto parts stores in town.. U-Haul is the place where I bought the hitch for my '71... They had it in stock..
Old 08-19-2024, 10:36 PM   #8
jaye deluxe
34 inches from the outside of each frame rail. I don’t have access to the hitch to get measurements
Old 08-20-2024, 09:11 AM   #9
Dashman
Active Member
The difference in price from a 1/2 ton to a 3/4 ton is probably class III to class IV and tow capacity. The GM manual shows 16-7/8" from centerline to inside frame, so 33-3/4" inside to inside or a tad more than 34" out to out. The frame width at the rear is the same for C series to K series.
Dashman is offline   Reply With Quote
Old 08-20-2024, 10:30 AM   #10
jaye deluxe
Thank you Dashman, you referred to a GM manual. Is this something online or do you have a hard copy ? Were you able to look at both the 1968 C10 and C20 frame measurements to verify if there was any difference ?
Old 08-20-2024, 03:14 PM   #11
Dashman
Active Member
This is the document title that I found here: "ST_330_72_1972_Chevrolet_Truck_Chassis_Service_Manual_10_to_30", section 2, figures 3 & 4 with the table of dimensions.
https://67-72chevytrucks.com/vboard/....php?p=5781194
It's a 22MB pdf, and obviously specific for the 1972 year. I am not 100% sure that the frame widths are the same for all models between 67-72. Download the '68 service manual and you tell us.
