Old 08-22-2024, 11:29 AM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Cajun Tach Shop Upgrade
I bought the pictured Tach Board off EBay from the Cajun Tach Shop Store and a friend installed in my factory original tach. My tach was always reading 7-800 RPM high at highway speeds. With this new board its very accurate now. Just passing along in case someone having the same issues. I have the Petronix Stock look Distributor and components on the truck.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-23-2024, 01:04 PM   #2
samkost
samkost's Avatar
Re: Cajun Tach Shop Upgrade
I can also recommend Greg @ https://www.cajuntachshop.com/
My OE tach finally gave up so I replaced it with an after market tach.
The replacement tachometer only lasted a couple of years.
I sent both to Greg for the upgrades he had been working on and he successfully repaired both.
Sam
1972 C10 LWB
2020 Z71 Tahoe
samkost is offline   Reply With Quote
Old 08-23-2024, 03:30 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Pertronix Ignitor I and II are OK with any Tach. Ignitor III is an electronic multi spark unit like MSD. A friend with a '72 F-250 and 429 BBF had the mark III, and his tach went crazy. He called Pertronix, and they told him to retrofit to a mark II if he wanted to run a Tach.
