Old 08-23-2024, 08:10 AM   #1
Rich84
Rich84's Avatar
Fuel Pump Not Priming
My 6.0 swap (2005 DBW) has been running flawlessly for about 7 years. Recently it has on occasion failed to activate the fuel pump when turning the key on which would cause it to fail to start. I cycle the key back to off and on again, then I here the pump prime and it runs fine.
Could this be the relay going bad? The pump?
Rich84 is offline   Reply With Quote
Old 08-23-2024, 09:59 AM   #2
Willie Makeit
Willie Makeit's Avatar
Re: Fuel Pump Not Priming
check your grounds. I've found that most electrical gremlins that involve components working "erratically" involve a bad or loose ground.
Willie Makeit is offline   Reply With Quote
Old 08-23-2024, 01:36 PM   #3
A1971Blazer
A1971Blazer's Avatar
I agree with Willie M....check grounds first, then check for power to the fuse and to the relay with key in run position.
The PCM sends 12v to the fuel pump relay to trigger it.
It could possibly be the relay is going bad and failing intermittently.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 08-23-2024, 01:47 PM   #4
Accelo
Accelo's Avatar
I believe it is the other way around.
The PCM grounds the fuel pump relay to trigger it.
Accelo is offline   Reply With Quote
Old 08-23-2024, 02:16 PM   #5
A1971Blazer
Maybe on some? but not on mine.
1967 C10 Step side
1968 C10 Step side
Old 08-23-2024, 04:38 PM   #6
LS short box
Either pos or neg supplied to the relay just get a new one and see if it helps. Relays are cheap but buy a "good" one.
LS short box is offline   Reply With Quote
Old 08-26-2024, 10:37 AM   #7
Rich84
Rich84's Avatar
So Saturday morning I turn the key with the relay in my hand. I feel it click but it does not prime. Tried it twice. I swapped in a new relay and it worked as it should. I drove the truck all weekend with no issues.
I tossed an extra relay in the glove box.
Old 08-30-2024, 10:03 AM   #8
RLC
If your problem returns it might be your fuel pump. I had this same issue on my 2001 Silverado 5.3. It would not start after the vehicle set for over a couple hours. I would cycle the switch on/off three or four times and it would start fine. I am not sure of the exact pressure, but the fuel system should retain some pressure when it sets. I checked my fuel pressure after the truck set for a few hours and it would drop down to nothing. It was the fuel pump; replaced it and no more issues.
RLC is offline   Reply With Quote
