Rough idle- low vacuum
So I got a 1972 K5. It always had a bit of a rough idle. It bugged me and so eventually I swapped out the engine for a new crate 350 from Blueprint. The only parts I didn’t swap were the intake manifold, the carburetor, and the distributor. But the new engine still had a sloppy idle. The kind that is slightly inconsistent, that throws the timing light off every so many bleeps. Anyway… since then I’ve swapped the carburetor (for another same Edelbrock 1406,) swapped out the distributor, taken out and reinstalled the intake manifold, studied the carb in depth and learned everything about tuning it, and hunted down every possible place I can think of for vacuum leaks (around the intake manifold, base of carb, surface of intake, valve covers, disconnected any and all hoses and lines including break and transmission,) and yet… rough idle and vacuum at 15 jumping around a bit as it sputters. When I accelerate it sounds and runs great. But to keep it from dieseling I have to run out the air mixture screws 2.5 turns. I set my idle rpm at 800. What else could it be?
