Old 08-25-2024, 07:38 PM   #1
merman
Suggestions for upgrades to tow? 79 C10
Hi all, I've browsed around and seen a variety of threads and suggestions on rear end and engine/trans combos for towing. I have a 79 longbed RWD that I'm looking to upgrade for towing. It currently has a 350 in it, but I'm not sure about the trans or rear end; I'm planning on replacing the trans and rear end to suit my needs. If anyone has any suggestions for towing 6000lb, I would appreciate the input. Also, I do plan on going up mountains fairly regularly with it. Thanks in advance!
merman is offline   Reply With Quote
Old 08-26-2024, 09:04 AM   #2
Dead Parrot
Re: Suggestions for upgrades to tow? 79 C10
Another thing to check is what rear spring setup you have. 6000lb trailer = about 600lb tongue weight. Probably want the HD spring setup.
Also check the brakes. IMO, you want the HD brakes if you are doing mountains.
Going with a hitch or do you have properly rated towing bumper?
Dead Parrot is offline   Reply With Quote
Old 08-26-2024, 11:13 AM   #3
kwmech
6 ply tires (minimum). Frame mounted receiver hitch. Trailer brake controller. HD brakes front and rear. HD rear springs. Shift kit in the transmission and a cooler. Proper gearing depending on tire size. You're going to be towing a trailer that is heavier than the truck
Old 08-26-2024, 11:25 AM   #4
mongocanfly
mongocanfly's Avatar
Might consider airbag helpers...
Def add trailer brakes..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-26-2024, 07:52 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
if you really want to go crazy get a 4L80 trans and stand alone controller i dont haul with the old stuff but i had a 2007 GMC that was bulletproof for towing ( 8000 lbs) almost 170K on it
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-26-2024, 08:57 PM   #6
merman
Nice, thanks for the suggestions so far! I'll keep reading up to learn about the tire size and rear end ratios to get a feel for what would be 'best' given the situation.
Old 08-27-2024, 04:23 PM   #7
SCOTI
SCOTI's Avatar
I have a Squarebody CC dually ('89 w/a rebuilt TBI 454/TH400/Dana HD70 combo) & I also own a '99 3/4-ton CC short bed (efi Vortec 350/4l80e/14bolt).
They've both pulled stuff for my needs (20' steel floor open car hauler w/an occasional/usual classic vehicle load). The big-block def get the program going quicker from a stand-still but the 350 gets it done fine.
Both have the HD F/R brake set-ups.
Both have 4.10 gearing with ~30.5 ('99) & 31.5" ('89) rear tire heights.
The '99 is def nicer w/the 4l80e/OD when doing anything on the highway.
Beyond the HD brakes & OD, I'd say the best cooling system possible (big radiator, big/effective aux trans cooler, best fan set-up) to help keep temps from cooking the mechanicals.
As mentioned..... Proper load rated tires. My rear tires are all load rated. I utilize LT fronts though vs D or E load rated. If I were to be hauling 'work equipment' type of loads for extended highway trips, I'd utilize load rated (8 or 10-ply) @ every position.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-27-2024, 11:07 PM   #8
merman
@SCOTI, thanks for the detailed suggestion! Glad to hear another endorsement for the 4L80e
Old 09-05-2024, 01:00 PM   #9
kipps
Brakes are key to towing capability. Are you willing to give up your 15-inch tires and five-lugs for 3/4-ton components? I'm reasonably certain that c20 spindles and brakes can be fitted to a c10, and if you're swapping the rear axle anyway, might as well.
What's the GVWR of your truck? Can you keep the weight of the truck, the cargo, yourself, and the tongue weight of the trailer within that GVWR?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 09-05-2024, 01:54 PM   #10
bnorth
I'm a big fan of airbags for the adjustment of having a comfortable stock ride and then airing up to haul a load and also maintain better weight distribution on the front truck axle. 6000# is getting up there for a 1/2 ton truck in the mountains. I would ensure top notch engine and transmission cooling and 10ply tires that are properly inflated. There are also some givens such as functioning trailer brakes and a brake controller.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
Old 09-08-2024, 05:20 PM   #11
Corts60
Just here to tinker
Corts60's Avatar
X2 for the HD brakes front and rear. Most rigs can get a load moving, but getting it to stop is a different story. If you want to keep your set-up old school, you can’t go wrong with T400 and gear vendors set up. Gives you under/overdrive options or 6 gears. The T400 is bullet proof if cooled with its own external cooler. If you’re towing 6k lbs consistently, 410 gears for sure.
And I agree with above about HD springs and possibly airbags depending on your needs.
