08-30-2024, 08:20 PM | #1 |
Junior Member
GM Automatic Tilt Steering Column Shortened 2”
GM Automatic Tilt Steering Column Shortened 2”. It has been shortened to give more room between the steering wheel & the seat, moves the steering 2” closer to the dash. So if you are a big guy it gives you some more room. The column was stripped down & checked for worn or broken parts & replaced if needed. Column was painted back black & the reassembled using the following new parts. Turn signal switch & wiring harness with the correct curved wire connector, neutral safety switch, lower bearing, lower bearing retainer, upper & lower rubber seals, inside tube seal, shift indicator pointer, shift indicator lense, hazard light knob, shift lever, turn signal lever, tilt lever & cancel cam / horn contact. It is ready to bolt in & go.
$675.00 Plus Shipping / Shipping to the US only. Posted via Mobile Device |
08-30-2024, 08:23 PM | #2 | |
Junior Member
09-01-2024, 01:14 AM | #3 |
Re: GM Automatic Tilt Steering Column Shortened 2”
Hey Don, im very interested. Can you give me a day to organize shipping? I just have to confirm things.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
09-01-2024, 02:02 PM | #4 |
I’ll take it.
Pm sent.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 Last edited by YBNORML; 09-01-2024 at 02:42 PM. Reason: Details |
09-07-2024, 02:06 PM | #5 |
I'll take this if the deal with YBNORML falls through.
09-10-2024, 07:12 PM | #6 |
Junior Member
