Old 08-30-2024, 09:29 PM   #1
Luke87gt
Luke87gt's Avatar
Thermostat Change on 250 i6. Thread sealer on bolts?
Hi guys, I will be swapping the thermostat on the 1969 250 i6
Question: Do the two thermostat housing bolts require thread sealer? I don’t recall if water has access into those two threads.
If thread sealer is needed, which loctite do you recommend?
Thank you!
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 08-31-2024, 03:18 AM   #2
lil hoodlum
lil hoodlum's Avatar
Re: Thermostat Change on 250 i6. Thread sealer on bolts?
Sorry, I don't know about inline 6's, but on a small block it isn't necessary.
For thread sealer, I like to use teflone tape.
Hopefully, someone more knowledgable on inline 6's will post the information you're looking for.
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 08-31-2024, 04:10 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Thread Sealer isn't necessary on L6 T-Stat housings.
The Thermostat Housing is on an assembly that bolts onto the front of the block. No contact with the water jacket.
Old 08-31-2024, 09:27 PM   #4
Luke87gt
Luke87gt's Avatar
Thank you for the confirmation
1969 C10 Shortbed
Old 08-31-2024, 10:10 PM   #5
'68OrangeSunshine
Sure
