Old 08-31-2024, 12:32 PM   #1
kna4977
OEM Battery?
Which Delco Battery/Batteries would a 1972 Blazer have come with new?
kna4977 is offline   Reply With Quote
Old 09-01-2024, 07:20 AM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: OEM Battery?
The side terminal R89/R89W is for 1971-72.
If you want to use a modern battery, they also make toppers:
Old 10-19-2024, 09:08 PM   #3
kna4977
Re: OEM Battery?
Where can I get a set of correct battery cables? Currently has top post cables.
Old 10-20-2024, 12:14 AM   #4
truckster
truckster's Avatar
Re: OEM Battery?
I got mine from Rock Auto.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 10-20-2024, 07:17 AM   #5
1970cstblazer
https://67-72chevytrucks.com/vboard/...ghlight=CABLES
Old 10-20-2024, 12:02 PM   #6
kna4977
Re: OEM Battery?
Saw that but not sure he's still doing them.
How long are the original cables supposed to be for a 72 4x4 with A/C maybe I can make something universal work
Old 10-20-2024, 01:04 PM   #7
1970cstblazer
Exclamation Re: OEM Battery?
Don't bother. Get the right stuff the first time.
If Roger does not produce them, check with M&H or Lectric Limited
https://www.lectriclimited.com/shop/...-ground-straps
Old 10-26-2024, 09:59 PM   #8
kna4977
Re: OEM Battery?
Roger reached out to me last Monday in response to my request and said he had a set of cables for my application so I sent payment. I haven’t heard anything since then despite multiple inquiries via PM and email.
I guess worst case scenario I’m out $160 and have to continue to search.
He was last active yesterday at 7:43 pm and hasn’t responded to my PM or email inquiries.
Old 10-27-2024, 07:05 AM   #9
1970cstblazer
Please be patient. He is a very well respected member in the truck hobby. He will come through and you will be happy with the product.
Old 11-02-2024, 11:33 AM   #10
kna4977
Re: OEM Battery?
Where/whaf is the ground strap supposed to bolt to? Currently grounded to the front of passenger head right behind the a/c compressor bracket. The secondary ground looks like it might attach to the passenger side inner fender. There’s a hole there for a bolt. Anyone know what size bolt needs to go there to attach it?
