Old 09-01-2024, 04:14 PM   #1
8man
Door hinge captured nut
I had to cut the bottom bolt of the driver's side lower door hinge to get it off. When I was trying to back the bolt out, the captured nut inside the frame stretched the steel holding it in place, and the nut started to spin. So, I cut the bolt to get the door off so I could keep moving.
Now that I have the cab clean and home, I've been trying to get the remaining part of the bolt out. I am not having any success.
My last attempt was to use a set of vise grips over the nut to try and hold it against the frame so it wouldn't move and use another vice grip to back the bolt out. All I succeeded in doing was stretch the steel capture some more when the nut still moved.
Any ideas on how to get this bolt out?
Thanks.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
