Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-02-2024, 11:47 AM   #1
Old Paint
Question `99 S10 Blazer noise
Not sure if this is the right area for this question. I have a `99 S10 Blazer with the 4.3 V6. There is a noise like a howling vacuum cleaner coming from the hose that runs from the manifold to the brake booster. I`m wondering if there is some kind of valve in that fitting or just what I will find when I pull this apart. Anyone ever experience this problem ? Thanks
Old Paint is offline   Reply With Quote
Old 09-03-2024, 09:41 AM   #2
leegreen
Re: `99 S10 Blazer noise
sounds like a vacuum leak, hose or fitting is loose, cracked badly
leegreen is offline   Reply With Quote
Old 09-06-2024, 02:49 PM   #3
HO455
HO455's Avatar
I'd say the same. My 91 had a hose develop a hole on the underside that made a similar noise. The hose looked good from above but until I ran my fingers down the hose with the engine running I didn't know what the issue was. The hose simply had a 1/4 inch spot that rotted away.
RIP Bob Parks.
Old 09-07-2024, 05:13 PM   #4
Old Paint
Thanks guys. I`m going to check it out again tomorrow.
