Help Identifying SWB frame
I purchased this frame for a 72 c10 short bed build I am doing. It was advertised as a 72 frame. Can someone please help me confirm this before I spend time on getting this thing ready. It has front disk and drum rear. Its hard for me to tell the difference between the years as they as look so similar. Thank You!
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Re: Help Identifying SWB frame
'72 would have disc brakes. I believe that the serial number is stamped on the frame, but it may not include the year information. If you can't find welds or fish plates, it's probably the real deal.
All about them K’s
![]() Join Date: Jun 2014
The top of the drivers side front frame rail near the steering box should have a partial vin stamped in it. It will have the year, plant code and sequence number of the vin. As an example my 72 K20 has 72J160173 72 for the year, j for Janesville, and 160173 as the build sequence number; 1 is a check digit. Mine was the 60,173 truck to roll out of Janesville in the 72 model year.
If you’ve got front disks it’s most likely a 71-72 frame.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
It's possible they could have been changed, but t clam shell engine mounts also say it's '72.. As others have said, the numbers on the frame will tell the story...
#5 | |
![]() Join Date: Dec 2014
If betting were allowed I would put a dollar on that being a 1971 frame, built in Baltimore. Which if google is correct, is a city that is somewhat near you.
https://67-72chevytrucks.com/vboard/...28&postcount=7
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
I don't know what the year is, but If you're piecing a frame to a cab, I recommend getting documentation from the DMV or State Police.
Every place is different, but up here in Kootenai County, ID, Vehicles being transferred from out of state are subject to a "VIN inspection". They WILL check the vin on the frame and if It doesn't match the title, they are likely to IMPOUND the vehicle (at the owner's expense) until it's figured out.
Insert clever text here: |
#8 | |
All about them K’s
Awesome fellas!! Thank you all for helping me out.
Roadtrip!
The clam shells on this one are 73 and up.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again... 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() Join Date: Jul 2007
The disk brakes and coil rear springs say 71/72. Motor mounts "should be" 73 or later but who knows what goes on during an engine swap.
I'll agree that even if you have a title to the cab it is a bit risky these days to not have it inspected because of the frame change and have that documented by the state. You need a bill of sale that states that you just bought the frame as parts or the receipt from the wrecking yard if it came out of a wrecking yard.
| Bookmarks |
