Old 09-11-2024, 11:55 AM   #1
kna4977
Radio 8-10 ohm speaker required before powering?
Original radios say to have the radio attached to an 8-10 ohm speaker before powering up. I see that also indicated in several threads, but why what's the reason what will happen if you don't?
kna4977 is offline   Reply With Quote
Old 09-11-2024, 12:04 PM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Radio 8-10 ohm speaker required before powering?
If you use a 4 ohm speaker for a long period, it will overheat the output transistors. 8 will work, but 10 is preferred with the vintage Delco OEM radios.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 09-11-2024, 12:05 PM   #3
kna4977
Right, but what if you just power it up with no speaker just to see if it lights up?
Old 09-11-2024, 12:25 PM   #4
1970cstblazer
Exclamation Re: Radio 8-10 ohm speaker required before powering?
That will damage the aforementioned output transistors. Make sure that any old Delco radio has the speaker hooked up before powering it up.
