Old 09-19-2024, 09:35 AM   #1
MacataQ
MacataQ's Avatar
more lighting issues
hello all
thanks to the fine people here, i am now pretty sure that i have a manual steering column modified to an automatic. this is evident by my lack of a NSS switch on the column and (so far) the lack of purple wires at/near the ignition switch area. now so far all of my lights work as intended, although almost all of them were blown when i first started digging into this. i have replaced and all is good. the only exception is my back up lights. is it possible that along with the fact that i can start in any gear that i also lost power to these? tested and 0V at socket. also in digging around i found what i believe is the connector for the backup lights tucked up under the dash, the dark green wire does read +12v volts with the ignition switched to ACC or IGN. the Light Green wire reads 0V in any position.
would appreciate any advice or suggestions anyone here might have!!!
thanks
Mac
MacataQ is offline   Reply With Quote
