Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-19-2024, 09:18 PM   #1
'68OrangeSunshine
'68OrangeSunshine's Avatar
NO-START Gripe
'71 GMC Jimmy, K/1500 350/SM465/NP203/12Bolt 3.73.
Truck won't start since yesterday. Got a jump leaving a union meeting Tuesday.
Truck stalled again as I got on my driveway and I couldn't restart to move under shade. I put a 15 watt solar panel on the dashtop to recharge. Day later Batt read 12.8 VDC but wouldn't start.
Only a single CLICK from the solenoid.
System has been modified to use a Ford type solenoid on the fender.
Old 09-19-2024, 09:56 PM   #2
franken
Re: NO-START Gripe
Jump from the big battery terminal to the small S-terminal on the ford solenoid.
franken is offline   Reply With Quote
Old 09-19-2024, 10:46 PM   #3
'68OrangeSunshine
Re: NO-START Gripe
I'll try that tomorrow.
Battery was holding a charge of 12.87 vdc.
Old 09-20-2024, 12:00 AM   #4
franken
Re: NO-START Gripe
Measure the voltage with a load on the battery or it may lie to you.
Old 09-20-2024, 12:43 AM   #5
'68OrangeSunshine
Re: NO-START Gripe
I disconnected the Fusible link -- between Fender Connector and positive Batt Terminal.
Rang good.
Old 09-20-2024, 03:21 AM   #6
franken
Re: NO-START Gripe
Seems odd that it clicked the solenoid w/ a bad fusible link.
Old 09-20-2024, 12:05 PM   #7
RustyPile
RustyPile's Avatar
Re: NO-START Gripe
Rang good.
That's not possible.. You probably have something screwy going on...
RustyPile is offline   Reply With Quote
Old 09-20-2024, 02:12 PM   #8
'68OrangeSunshine
Re: NO-START Gripe
I only disconnected the Fusible Link for a VOM check. Zero ohms means it's good. I reconnected right after.
Old 09-20-2024, 05:56 PM   #9
RustyPile
RustyPile's Avatar
Re: NO-START Gripe
I'm glad you cleared that up.
Old 09-20-2024, 09:55 PM   #10
'68OrangeSunshine
Re: NO-START Gripe
Still no joy. My ''Expert'' told me to clean up my terminals with the wire brush terminal tool. No effect. And I also shorted the Batt In lead to the S Terminal on the F-Type solenoid. It clicked, but the Starter did not turn.
Still there's another solenoid, The Bendix type on the Starter itself. He said to poke it with a broom handle to maybe free up the contacts. No joy. Of course I'm not sure the end of the broom even hit the right thingie.
Hoping I do not have to replace the Starter. It was new in 2007.
With the tight fitting Heddmans, I hafta pull the headers to get at the starter.
Old 09-21-2024, 03:36 PM   #11
dmjlambert
dmjlambert's Avatar
Re: NO-START Gripe
Let's see pictures of your battery terminals.
Connect a voltmeter. Use alligator clip test wires available at the car parts stores.
Connect the negative lead (com) of the voltmeter to the battery negative terminal. Connect the positive lead of the voltmeter to various places where you will check the voltage while you are trying to crank the engine.
1. the positive battery terminal
2. the input from battery main terminal of the ford solenoid.
3. the output to starter main terminal of the ford solenoid.
4. the S start terminal of the ford solenoid.
5. the main terminal of the starter.
6. the engine block (expected to be 0V but if you get some voltage your battery negative cable is bad or badly connected.)
dmjlambert is offline   Reply With Quote
Old 09-21-2024, 11:04 PM   #12
franken
Re: NO-START Gripe
Jumper cable from battery + to the original solenoid. Jump to the S-terminal.
Measure battery voltage while the solenoid is engaged.
Old 09-22-2024, 05:11 AM   #13
'68OrangeSunshine
Re: NO-START Gripe
Kinda hard to do alone.
I tried a jump start with booster cables from the pickup to the Jimmy. No joy.
Old 09-22-2024, 05:22 AM   #14
franken
Re: NO-START Gripe
Not really.
Semipermanently jump from the big terminal to the S-terminal.
Connect one end of the jumper cable to the big terminal.
Connect the voltmeter to the battery.
Touch the other end of the jumper cable to the battery + terminal.
Old 09-22-2024, 04:30 PM   #15
'68OrangeSunshine
Re: NO-START Gripe
Not really.
OK. Somehow I was imagining being under the truck. But I can set the gator clip and stand up in front of the Battery. Much better.
Old 09-22-2024, 05:57 PM   #16
'68OrangeSunshine
Re: NO-START Gripe
I saw a package of Gator Clip Test Leads in Autozone for about $35!
I remember when you could get those at Radio Shack for under $5.
Old 09-22-2024, 07:58 PM   #17
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: NO-START Gripe
Read this and see if it helps.
http://www.67-72chevytrucks.com/vboa...d.php?t=655903
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-22-2024, 08:35 PM   #18
franken
Re: NO-START Gripe
You can use a bit of wire for no money from under the truck but feel free to make it as difficult as possible.
Old 09-22-2024, 09:34 PM   #19
'68OrangeSunshine
Re: NO-START Gripe
I may have to go with the "Most Difficult" option.
The Starter is tucked inside a 'cage' made by the Passenger side Headers. [ I did intend to paint them anyway.] To even get a clip onto the S Terminal of the OEM Bendix Solenoid, the RH header has to move. The Type F solenoid goes Clunk if shorted with a screwdriver across the S terminal and the Batt In Terminal.
I'm pricing new Starters at Jegs, Rockauto and Carparts.com.
Current starter unit was installed 4/2008.
Sixteen years is a good run, I guess.
Predicament is that the truck "landed" on my sloped front Driveway and I'd like to move it to a better spot for mission creep maintenance.
If I had a pal handy to watch the street, I could try a back coast into the intersection and pop the clutch. If it doesn't start, we could rig a ''Truck Rodeo" and he couLd drive the Stepside and tow me into posItion..
Old 09-22-2024, 10:10 PM   #20
dmjlambert
dmjlambert's Avatar
Re: NO-START Gripe
Is item #2 one of these emergency repair terminals? I changed a starter because of one of those, and I gotta say I don't like them worth a damn. Even if the cables appear nice and clean, they can betray.
Is item #1 the negative battery cable, is there a nice big fat cable I can't see that goes to the engine?
Old 09-22-2024, 10:13 PM   #21
dmjlambert
dmjlambert's Avatar
Re: NO-START Gripe
You can do all of the tests on my list except 5 without getting in the cage, and a test may reveal something.
Old 09-22-2024, 11:03 PM   #22
'68OrangeSunshine
Re: NO-START Gripe
Attachment 2393689
Item 1 is the Negative Terminal. The Quick Disconnect lead is disconnected so nothing bleeds off while sitting. Yes. the Positive Lug [Item #1] can be replaced. I can do that tomorrow. Definitely should be done before buying new compnents.
