Old 09-22-2024, 01:02 AM   #1
SGLTRK
Clutch pedal question
Hi All,
I have a '68 C10 pickup with a small block/turbo 400 that I'm swapping to a manual trans. I just got the clutch/brake pedal assembly in today. It has a lever
arm (?) that is located to the right of the brake pedal but is mounted to the clutch pedal shaft a moves with the clutch pedal. Is this an attachment point for the stock "Z" bar linkage?
SGLTRK is offline   Reply With Quote
Old 09-22-2024, 03:34 AM   #2
samert111
samert111's Avatar
Re: Clutch pedal question
Yes, that is the way my conversion from an auto to manual looks like. There should be a push rod assy that goes on the shaft and thru the firewall to the Z bar.
What are you doing for a neutral safety switch?
With this conversion you may find that the clutch pedal is 3-4" higher than the brake pedal which makes it awkward to operate the clutch with the stock 17" steering wheel.
I had to modify my pedal stop with a bolt and jamb nuts and adjust the pedal stop lower in-line with the brake pedal, which then messed up my clutch adjustments and to get enough pedal travel I had to remove my conversion neutral safety switch on the floor and bypass it. Now it's like the old days, just make sure the trans is in neutral or push the clutch in to start the engine.
samert111 is offline   Reply With Quote
Old 09-22-2024, 06:33 AM   #3
SGLTRK
Thanks Samert111.
I have dealt with "Z" bar manual linkage before but always in cars. With those the link bar goes directly from the pedal to the left end of the "Z" bar. Oppisite of the truck setup appearently. I'm going with a hydraulic clutch release so I'm eleminating the whole "Z" bar system. I'm not concerned with a neutral safety switch. They didn't exist when I started driving and I've never seen a need for them. Thanks again for the verification.
