Old 09-22-2024, 02:45 PM   #1
Speedracer39
Speedracer39's Avatar
72 c10 inner door panel question
I was wondering if I removed the wood grain insert if the plastic underneath was smooth or textured and if I did remove the wood grain would I be able to put the trim back on. If not I’m looking for suggestions on a good quality insert for both sides. Thanks
Speedracer39 is offline   Reply With Quote
Old 09-22-2024, 05:19 PM   #2
best view
Re: 72 c10 inner door panel question
It’s textured and you can take it off and put it back on
best view is offline   Reply With Quote
Old 09-22-2024, 05:25 PM   #3
howzzzit
howzzzit's Avatar
My 72 Cheyenne had scroll underneath the panels. I refinished the panels and went back with the chrome trim only and I like it. I don't know why they added wood grain door panels to my interior. Nothing else is wood grain. Just be careful with the pins on the trim pieces. They're only good for so many bends back and forth and they'll snap off. I know LMC sells a set and probably others. Also, behind the panels are donuts on the handles I assume to keep the panel from bowing inward. The originals I believe are rubber. I bought a set from LMC and they sent cheap lightweight foam. I made my own. Plastic wood grain inserts as well as metal inserts are available Haven't seen either one, but I sure someone on the forum can answer which is better.
howzzzit is offline   Reply With Quote
Old 09-23-2024, 07:35 AM   #4
1970cstblazer
1970cstblazer's Avatar
Talking Re: 72 c10 inner door panel question
On my 1970 Blazer, I took OEM 1972 Blazer CST panels, removed the woodgrain inserts, and replaced the stainless trim. The scroll pattern matches the 1970 seats.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 09-23-2024, 07:25 PM   #5
58 Special
Junior Member
I did the same on my GMC K15 Suburban
58 Special is offline   Reply With Quote
Old 09-23-2024, 07:54 PM   #6
Speedracer39
Thanks for the replies. I was hesitant to bend over the wires not knowing what was underneath. I’m going to remove the wood grain inserts tomorrow and post pic afterwords.
Old 09-24-2024, 01:53 PM   #7
Speedracer39
I was lucky enough not to break any mounting wires and happy with the results
Old 09-24-2024, 05:09 PM   #8
CG
BlahBlahBlah
Looks much better than the banged up wood grain. Nice job.
Old 09-24-2024, 07:19 PM   #9
samkost
samkost's Avatar
Excellent, that came out great
I also fitted some trim to my standard panels.
Yes you do need to be careful with the old frail tabs.
Sam
1972 C10 LWB
2020 Z71 Tahoe
samkost is offline   Reply With Quote
Old 09-24-2024, 07:29 PM   #10
chewychevy67
The standard style with the trim added look great in 67 68 trucks. They match the interior styling without the scrolls.
chewychevy67 is offline   Reply With Quote
Old 09-25-2024, 07:09 AM   #11
1970cstblazer
Thumbs up Re: 72 c10 inner door panel question
Looks great!
