Old 09-22-2024, 11:40 PM   #1
BADAZZ86
Angry 1990 R3500 454 crew cab dually need help
I have a 1990 R3500 crew cab dually with a gm crate 454 that has a no start situation when the engine has ran for more than 15mins. I have replaced ignition coil, spark plugs, wires distributor, cap, distributor, rotor and complete distributor and have no idea what to do now if it sits for 20 minutes it’ll restart but if you run it and then shut it off, it will not restart immediately. you have to wait 20-30 minutes. It’s not the starter because it cranks over just fine just does not start. Will start when the engine is cool or cold just fine. Looking for any assistance with this craziness
BADAZZ86 is offline   Reply With Quote
Old 09-23-2024, 01:45 AM   #2
RustyPile
RustyPile's Avatar
Re: 1990 R3500 454 crew cab dually need help
Welcome, newcomer to our site..
The first thing you need to do is stop throwing parts at it, hoping something will stick. Three things needed for an I/C engine to run -- fuel, air, spark.. Camshaft and valve timing provide the air. So that leaves two items.. Remove any one of the spark plug wires and attach a spark tester.. If you don't have spark, any one of several components could have failed. You've already "shotgunned" most of the spark components but obtain a flow chart for testing for no spark condition.
If you have spark, then the only item left is fuel.. Could be a fuel pump failure, fuel pump relay failure.. Also extremely low oil pressure can cause the fuel pump to shut off.
RustyPile is offline   Reply With Quote
Old 09-23-2024, 07:04 AM   #3
BADAZZ86
I understand what you’re saying all the above items I stated were done as routine maintenance but the coil and distributor were done when the problem arose! The truck has dual tanks and both have new pumps about 2 years ago the truck doesn’t get driven much so in two years I bet it hasn’t seen 600-800 miles. I went through it fromt to back when i got it.
Anyway back to the problem at hand! It ran fine not a problem until about a month ago just a routine cruise out to wash it and stoped at the car wash and this happened get it and just crank away no fire! Sit there trying to figure out how I’m going to get it back home and waiting on a ride and about 30 minutes goes by and bam starts back up drove home fine pulled in the garage shut it off same problem no restart tried again next morning start right up! Has done it multiple times now same situation each time and neither tank work is why I don’t think it’s a pump problem when it happens.
Old 09-23-2024, 04:25 PM   #4
beasst
beasst's Avatar
I had a 71 Monte Carlo years ago. Did the exact same thing. Turned out to be the hot battery cable from the battery to the starter was too close to the exhaust manifold and would get hot. Car would not restart for 20 to 30 minutes then would start fine until you shut it off again.
Just a thought
beasst is offline   Reply With Quote
Old 09-23-2024, 09:04 PM   #5
BADAZZ86
I will examine that too when yours did that would it crank over just not start? Mine cranks over fast and strong but will not start until whatever is failing cools off
Old 09-25-2024, 07:42 PM   #6
RustyPile
RustyPile's Avatar
Originally Posted by BADAZZ86 View Post
I understand what you’re saying all the above items I stated were done as routine maintenance, but the coil and distributor were done when the problem arose! The truck has dual tanks and both have new pumps about 2 years ago the truck doesn’t get driven much so in two years I bet it hasn’t seen 600-800 miles. I went through it front to back when i got it.
Anyway, back to the problem at hand! It ran fine not a problem until about a month ago just a routine cruise out to wash it and stopped at the car wash and this happened get it and just crank away no fire! Sit there trying to figure out how I’m going to get it back home and waiting on a ride and about 30 minutes goes by and bam starts back up drove home fine pulled in the garage shut it off same problem no restart tried again next morning start right up! Has done it multiple times now same situation each time and neither tank work is why I don’t think it’s a pump problem when it happens.
All that typing and nowhere did you say anything about the results of the tests I suggested.. The car wash may or may not have anything to do with the problem. You "THINK" it's not the fuel pump?? How did you come to that conclusion?? Have you actually tested the fuel pressure?? Assume nothing. Just because an item was replaced at some point in the past doesn't eliminate it from the list of suspects.. No one on this forum can walk up to your truck and point to the cause.. They, including me, certainly cannot do that from a computer keyboard.. Systematic troubleshooting is the needed approach.
The troubleshooting flow chart I mentioned can be found in the Factory Service Manual.. If you expect to keep a 35 year old vehicle on the road using your own wits and means, the number 1 tool is that manual..
Old 09-25-2024, 08:14 PM   #7
BADAZZ86
The reason I don’t think it’s the fuel pump is one that it has dual tanks with dual pumps and neither work when it dies and it doesn’t stall or lack fuel when it is running only has a restart issue after it is shut off once it reaches operational temperature.
Old 09-25-2024, 10:21 PM   #8
RustyPile
RustyPile's Avatar
OK, So Here's the step you've taken:
(1) Checked fuel pressure. Found neither fuel pump functions..
Here's the steps you need to take.
(2) Refer to Service Manual for steps and procedures to determine why pumps (both) don't run.. Check fuel pump fuses, relays, and presence of voltage to fuel pump "control system"..
I've already told you that no one, including me, can tell EXACTLY why the engine won't start.. There is a sack full of items involved in the fuel delivery system.. Failure of any one of them can and will cause this problem.. Obtain that flow chart and then come back here if you can't decipher the troubleshooting directions.
Old 09-25-2024, 10:28 PM   #9
RustyPile
RustyPile's Avatar
Go here:
https://www.gmtruckclub.com/threads/...oblem.1472109/
Old 09-26-2024, 09:05 AM   #10
rdc72
For what its worth, Ensure your timing is correct as well as the vacuum advance hose is connected, if its off a little it can cause the get hot and no start or very slow start, at least it has for me in the past.
rdc72 is offline   Reply With Quote
Old 09-26-2024, 01:39 PM   #11
straight6chevyguy
straight6chevyguy's Avatar
Unless I misunderstood I think the op was referring that neither pump or fuel tank would "work" to make it start. I didn't see where he said that the pumps weren't actually working. If I missed something my bad. If op has not checked fuel pressure yet it would be a good idea to do that next.
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 09-26-2024, 02:23 PM   #12
Keith Seymore
Keith Seymore's Avatar
Still TBI, or converted to carburetor?
During that period when it is acting up will it start (and run) on starter fluid?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-06-2024, 03:28 PM   #13
wyattglock
wyattglock's Avatar
I had a similar problem with my 89 R3500 454. I put new AC Delco pump motors into the sending units. I believe I used the 486 or 386, can't remember which exactly after 12 years.
I also put a Ford solenoid on the fender well, and ran new wire to the starter. With headers, I had a really bad heat soak problem that would cause very similar issues to yours.
After all that, the tank selector switch went bad. If you replace it, make sure you get the switch that stays on.
wyattglock is offline   Reply With Quote
Old 10-07-2024, 09:23 PM   #14
Pontiac1976
Pontiac1976's Avatar
Have to agree with rdc72 and or Dist is in correct setting not one or two teeth late or early.
Ensure your timing is correct as well as the vacuum advance hose is connected (A large Vacuum Gauge can help a lot doing tune up timing and timing gun
double check will not hurt
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 10-08-2024, 04:02 PM   #15
SCOTI
SCOTI's Avatar
I don't think the '90 model TBI engine utilizes vacuum advance. IIRC, the computer is controlling advance.
I'm curious if it's a possible vapor lock related issue? my 89's lines come up the back of the block on the passenger side & were routed close to the exhaust. When I swapped to headers & new exhaust, I slipped some DEI heat shield wrap on the lines where they crossed over the exhaust.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-09-2024, 09:35 PM   #16
Pontiac1976
SCOTI
You be right , unless it be switched to carb.
SCOTI you could be right about the vapor lock related issue, but if timing off. That can cause similar problems since he had the Dist. out put new one in. is it bang on or is it off by one or two teeth or + or - any will mess with timing. big Vacuum Gauge really help telling you info.
Old 10-10-2024, 09:13 AM   #17
SCOTI
SCOTI's Avatar
Originally Posted by Pontiac1976 View Post
SCOTIYou be right , unless it be switched to carb.
Agreed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
