Old 09-27-2024, 03:03 PM   #1
WorkinLonghorn
WorkinLonghorn's Avatar
Plugs and Wires for Chinese HEI ?
I need to know what is the best option for my GM crate 350 ("stock replacement") low-po engine. Fixing it up for the sale and I want it to really purr. '69 Owners manual says "R-44" . Maybe just tell parts counter I have a 1979 Chevy? .040" gap or ? Also I think if I do tell them it's a '79 the wires are too short and have to be routed OVER the ram's head exhaust manifolds. What do you guys use for plugs and wires? Thanks, Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 09-27-2024, 05:22 PM   #2
RichardJ
Re: Plugs and Wires for Chinese HEI ?
>> '69 Owners manual says "R-44"<<
Plug with square shoulder and gasket.
Does your crate engine heads have tapered seat plugs? R44T
What plugs are in it now? Didn't you replace the plugs and wires when the newly installed crate engine was initially running rough?
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 09-27-2024, 05:59 PM   #3
54blackhornet
54blackhornet's Avatar
I bought an inexpensive BravX HEI for my 71 C/20. First one lasted one year. Replacement lasted six months. Third one has been working fine for over two years. Moral to story. Great customer support pays off. I used 8 mm wires from Napa. Truck starts much better than it ever did before.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 09-27-2024, 09:53 PM   #4
WorkinLonghorn
The plugs in it now are ACDelco 45TS and you're correct about it running rough at first. I checked the valves and a number of them were tightened WAY past spec, If I recall, some were like 2 or three whole turns past spec.
Now there is a miss. I'll just get some of what was in there and gap them to .040 I guess.
Old 09-27-2024, 09:56 PM   #5
WorkinLonghorn
Yeah, I've been through a few myself but this last Skip White Chinese Distr. has been going for 6-7 years. I don't drive that much anymore though.
Old 09-29-2024, 09:51 AM   #6
67swb72klb
67swb72klb's Avatar
late 70s Vette wires always work for me..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 09-29-2024, 10:06 PM   #7
Mike C
Mike C's Avatar
Your original motor would have had washer seat plugs and anything after 72 or so would have taper seat plugs. So I would assume your trucks crate motor has taper seat plugs. Just get some for something like a 1980 truck. 75-79 Corvette plug wires route like the original 67–72 truck wires but have HEI terminals on the cap end.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-03-2024, 11:13 PM   #8
WorkinLonghorn
OK thanks. I'll ask for Vette wires.
Old 10-04-2024, 12:28 AM   #9
Sheepdip
Sheepdip's Avatar
Just make sure the rest of the truck is up to snuff to handle the extra
Horse Power those Corvette spark plug wires will give it!
Sheepdip is offline   Reply With Quote
