Dome light
I have the AAW wiring kit installed with the courtesy switch in the door. The door switch work good but the dome light is grounding out thru the socket. Its a one orange wire light with the ground going thru the door switches. I think all I need is a plastic socket that wont get a ground. I either need a source for a 1 wire socket or a 1 wire whole new dome light. All the dome lights online are showing 2 wires. Can I use a 2 wire dome light and just not use the white ground?
| Bookmarks |
