10-02-2024, 04:48 PM | #1 |
thinair
1979 k20
1979 Chevrolet Scottsdale · Truck · Driven 100,000 miles
1979 K20 Scottsdale Idaho truck with very little rust. Each cab corner has some rust and the drivers box side has some rust behind the wheel opening as seen in the pictures. Floor pans had rust and have been cut out and have had new metal welded back in. 454. TH350. NP203. Corporate 10 bolt front and Corporate 14 bolt full floater rear 4.10 gears. Older 35" BFGs on 16.5 x 9.75 steelies Hickey push bar on the front. Tach dash that works. Aftermarket voltage, temperature, and oil gauges that are all hooked up and working. New windshield. New fuel senders. New carpet. New fuel pump. All 4 cab mount bolts and all 8 bed bolts came out with the impact or ratchet. None have been cut or replaced. 454 is a mid 70s pickup engine #361959. Rebuilt at some point with an RV cam, Edelbrock intake and headers. At operating temperature each cylinder has 120lbs compression and 50lbs of oil pressure. ***** I do not know the actual mileage on the engine* $15k Located in Omaha Nebraska Last edited by thinair; 10-02-2024 at 04:49 PM. Reason: Price and location |
10-02-2024, 05:30 PM | #2 |
thinair
Re: 1979 k20
Pics
