Old 10-02-2024, 08:01 PM   #1
david7w5@gmail.com
1972 Marker and running lights
I have a 1972 C30, when I turn on the first pull of the marker lights, the front side and bumper lights does not light up. It has a flat bed so no rear marker light. My headlights work, rear taillights, brake lights, and hazard lights work. When I turn on the blinker the front marker light flashes.
I owned a 69 in the past and the marker lights didn't flash.
What would cause this problem?
david7w5@gmail.com is offline   Reply With Quote
Old 10-02-2024, 10:07 PM   #2
dmjlambert
dmjlambert's Avatar
Re: 1972 Marker and running lights
Burned out fuse in the fuse panel, or bad parking light bulbs in the bumper are the top suspects.
dmjlambert is offline   Reply With Quote
Old 10-02-2024, 10:36 PM   #3
KSCHEVYUP
KSCHEVYUP's Avatar
Make sure you have a good ground.
1972 C30 Cheyenne Super
1971 C10 (Parts truck)
KSCHEVYUP is offline   Reply With Quote
Old 10-03-2024, 12:10 AM   #4
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Just an FYI 72 marker lights are supposed to flash.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 10-03-2024, 05:40 PM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
Sounds like a 1967. [They had no Side Marker Reflectors.] The Turn Signal Lights worked L & R to signal turns. Hazards blinked all around. On first click, They came on as Parking Lights.
Second click, the Headlights came on but the front yellow lights went out. [Except for indicating turns]
A PO may have used a 1967 Model Year Headlight Switch.
In '68 the Side Marker Reflectors were installed, but had no lights. The Running lights stayed on with the headlights.
'69 I think, they were optionally lighted. IDKFS.
By '71 all the Marker lights were on, and the fronts alternated blinks with the front side lamps. Red rear markers don't blink.
