10-03-2024, 05:49 PM | #1 |
Clutch Fork
Original GM clutch fork used by GM from early 60's and up to '72. GM part # 3765374. Good spare part to have on hand. Don't have a pic right now but if you need one you know what they look like, LOL. Good solid with no edge wear at the throw out bearing section. No inner clip. $10 plus shipping, do not have Paypal.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
10-04-2024, 03:50 PM | #2 |
Re: Clutch Fork
Gary, what would shipping be to 46590?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
10-04-2024, 05:04 PM | #3 |
Re: Clutch Fork
Mark, will get a quote for you by this evening.
10-04-2024, 08:38 PM | #4 |
Re: Clutch Fork
Mark, sent you a PM.
10-05-2024, 04:50 PM | #5 |
Re: Clutch Fork
Gary, will it work with a big block? I might put a manual trans back in the beast.
10-05-2024, 07:39 PM | #6 |
Re: Clutch Fork
Mark, honestly can't say for sure on that.
10-05-2024, 08:52 PM | #7 |
Re: Clutch Fork
Mark, thinking on this more, wasn't the 396 BBC available in '69 C20s and on up thru '72? Would have thought more than one 3/4 ton 2wd truck was outfitted with a sm465 4 speed transmission. I know that the general thought is NO 4WD trucks were available with a BBC until later into the square body trucks.
10-06-2024, 09:03 AM | #8 |
Re: Clutch Fork
After doing more research, I am going to pass on this.
10-06-2024, 12:25 PM | #9 |
Re: Clutch Fork
Not a problem Mark, good luck on your manual trans venture.
Clutch fork still available, $10 plus shipping.
10-15-2024, 03:23 PM | #10 | |
Re: Clutch Fork
10-15-2024, 08:46 PM | #11 |
Re: Clutch Fork
That goes along with what I've found, that clutch fork was used in the later BBC equipped trucks from 69 to 72.
