Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 10-04-2024, 12:01 AM   #1
IDC10
Two Bad Fenders to Make One Good One?
The original driver's side fender on my '68 fits like a glove! The problem is that the front is bashed in badly and the attempted repair looks like garbage. I attempted to use a heavy amount of fiberglass filler and I just cannot get the profile right on the front.
I have a repop fender and it fits like crap! I took some measurements and the welds to the inside frame are way off. The skin on the outside seems fine though. I am tempted to try cutting the front outer portion of the repop fender off and welding it on to the old one to make one perfect fender.
Should I try it?
IDC10 is offline   Reply With Quote
Old 10-07-2024, 04:19 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Two Bad Fenders to Make One Good One?
All depends on how comfortable you are with cutting and welding I did a similar repair on a passenger fender . The OEM was really banged up so I cut the cup portion and the wheel well lip about half way . Took a lot of measuring and cutting and fitting but it tuned out well . What do you have to lose you don’t have a workable fender anyways so even if you don’t like the end result you not out anything . Last picture is letting it bake in the sun after I took it out of my spray booth
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-07-2024, 04:21 PM   #3
72c20customcamper
OEM drivers side is easier to find than passenger side fenders that’s why I ended up cutting the passenger side up .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 12-30-2024, 04:14 AM   #4
IDC10
Sorry, it's been a few months...but I did it, and it worked like a dream.
Used a combination of flange and butt welds and a little bit of body filler. Sealed the back of the welds with 3M panel bond epoxy.
upload images
upload images
upload images
upload images
Old 12-30-2024, 08:52 AM   #5
raggedjim
raggedjim's Avatar
Nice work, really like your truck. Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 12-31-2024, 04:16 AM   #6
IDC10
Thanks!
5 years of learning how to do paint and autobody in a small shop. Truck was painted right where it sits.
Old 12-31-2024, 07:30 AM   #7
raggedjim
raggedjim's Avatar
Originally Posted by IDC10 View Post
Thanks!
Post more pics when you get a chance. I'm using the same paint on my step side. Is it acrylic urethane? Single stage?
Roger
'70 GMC Jimmy 2wd
Old 12-31-2024, 03:03 PM   #8
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: Two Bad Fenders to Make One Good One?
I repaired the fenders on my 1970 Blazer using sections from severely dented but rust free 1972 fenders from my donor Blazer.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old Yesterday, 03:09 PM   #9
72c20customcamper
Came out great .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
