Old 10-07-2024, 09:44 PM   #1
kna4977
Fan Shroud, Normal Operating Temps, Issues?
How hot should a 1972 SBC 350 run and get to after it’s shut off?
Have a fan shroud but think the gap between the radiator and the shroud is too large not sure how I will rectify it but looking for opinions and advice.
kna4977 is offline   Reply With Quote
Old 10-07-2024, 10:14 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Fan Shroud, Normal Operating Temps, Issues?
First, get rid of that fan clutch eliminator and put on a clutch that will place the center of the fan blade edges at the edge of the shroud. That MAY take a couple of trial fits. I wouldn't worry about how hot the coolant gets after the engine is shut off. It's guaranteed to go up because of residual heat in the engine that is now not being carried away. 230° isn't an unusual temperature after shutdown. I've seen elsewhere here that a 195° thermostat was installed at the factory.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-07-2024, 10:33 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Agreed 100%. I'll add that you need a heavy duty clutch fan in good working order, and a factory-style 7-blade 18" fan. If it's puking out coolant after a hot shutoff, does it have a coolant recover system (overflow tank)? It should, including a double-seal 15# (or 16#) radiator cap made for a closed system. That way you can fill the coolant all the way to the top of the radiator and you'll never lose a drop.
There's a chance you might have a shroud for a 4WD truck. It's deeper than one for 2WD, because a 4WD engine sits farther back in the engine bay.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-07-2024, 10:52 PM   #4
NGN
NGN's Avatar
Looks to be a 4WD shroud. Also I do believe you need a clutch fan when you have AC
NGN is offline   Reply With Quote
Old 10-07-2024, 11:31 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yep, factory A/C in my K20 came with a clutch fan.
- Mike -
RIP El Jay
Old 10-08-2024, 08:07 AM   #6
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Fan Shroud, Normal Operating Temps, Issues?
Don't know the level of correctness you are going for, but 4WD Blazers/trucks used a steel connecting pipe for the upper radiator hoses with 4 tower clamps.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old 10-08-2024, 09:33 AM   #7
kna4977
Could you share a pic and how difficult are those parts to find?
Old 10-08-2024, 09:36 AM   #8
kna4977
No puking of coolant, no overflow tank has a 9# cap and it's 4x4. Shouldn't the fan clutch eliminator allow for more cooling since the fan is turning at the same speed all the time? What type of clutch would I be looking for if I go that route?
Old 10-08-2024, 10:03 AM   #9
jaros44sr
jaros44sr's Avatar
image by [url=https://www.flickr.com/photos/97391199@N06
Hoses are available on the parts board
Just sold one last week
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-08-2024, 12:02 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Not sure how cooling would be different, but with a clutch fan you get a lot less fan roar, plus a very slight improvement in fuel mileage. When additional cooling is required, the clutch engages and that wonderful 7-blade fan goes to work. Factory A/C includes a clutch fan so I figure there must be benefits.
Hayden 2747. https://www.rockauto.com/en/moreinfo.php?pk=1793510
- Mike -
RIP El Jay
Old 10-08-2024, 01:05 PM   #11
72SB
there are 3 levels of fan clutch made by Hayden. Standard, HD and Severe Duty. AC equipped want a HD
Hayden 2747
https://www.amazon.com/dp/B000C3F370...fed_asin_title
7 blade fan wants to be half in/out of shroud
72SB is offline   Reply With Quote
Old 10-08-2024, 01:07 PM   #12
kna4977
Hayden 2747
Thanks and which 7 blade fan should I look for if needed?
Old 10-08-2024, 01:09 PM   #13
kna4977
[quote=jaros44sr;9345920]image by [url=https://www.flickr.com/photos/97391199@N06
Just sold one last week[/quote]
Got any more? Did they have some kind of rubber hose on each end as well with the 4 tower clamps? Anyone know the reasoning behind using a metal hose?
Old 10-08-2024, 01:19 PM   #14
72SB
I have this one but other brands are available
https://www.npdlink.com/product/fan-...%3D7%26year%3D
get a coolant recovery tank for a 75 Nova and mount it inside the PS fender next to battery.
(pic of my 67 Camaro with the Nova tank)
Or buy the generic Dorman and mount it on core support
https://www.amazon.com/dp/B000E35UV2...fed_asin_title
Old 10-08-2024, 01:50 PM   #15
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The repro fan linked above by 72SB looks identical to my OEM fan.
Yes. I have seen correct OEM hoses on the parts board, but I just bought mine from NAPA. The one nearest the radiator is 6" long, the other is 4 1/2".
Because the engine is set back farther in a 4x4, a longer molded rubber hose *might* sag and contact the alternator belt. If that's not a concern for you, no worries. Unless you are going for full originality.
- Mike -
RIP El Jay
Old 10-08-2024, 03:08 PM   #16
HO455
Post Whore
HO455's Avatar
Here's a thread on repop metal tubes. It gives you an idea what the originals looked like.
https://67-72chevytrucks.com/vboard/...d.php?t=624805
RIP Bob Parks.
Old 10-08-2024, 03:09 PM   #17
HO455
Post Whore
HO455's Avatar
RIP Bob Parks.
Old 10-08-2024, 06:24 PM   #18
kna4977
I see a long spacer if that's what is meant by fan clutch eliminator. What does the factory fan clutch setup look like what all parts am I missing?
Old 10-08-2024, 06:53 PM   #19
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The fan clutch bolts directly to the water pump flange (sandwiching the pulley, of course) with no spacers. The fan bolts to the rear of the clutch.
- Mike -
RIP El Jay
Old 10-08-2024, 07:37 PM   #20
Steeveedee
Who Changed This?
Steeveedee's Avatar
Fan clutch eliminators were a cheapo replacement for a not-really-that-expensive clutch. When I worked in a parts store, we sold those like hotcakes. Southern California does get hot.
~Steven
Simi Valley, CA
Old 10-08-2024, 07:39 PM   #21
kna4977
Would that put the fan far enough into the shroud as it’s currently got quite a long spacer on it? Currently has a 4 blade fan with no clutch.
Old 10-08-2024, 07:50 PM   #22
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I would think so, based on my K20 with OEM shroud & fan, and Hayden 2747 clutch which was a perfect replacement for my failed OEM fan clutch.
Distance from the fan mounting surface to the water pump pulley is roughly 1 1/2".
Also, in your pic it looks like the fan is sitting too far into the shroud -- meaning the spacer is likely too long.
- Mike -
RIP El Jay
Old 10-08-2024, 10:51 PM   #23
kna4977
having it too far in might recirculate hot air vs drawing or vacuuming in cool air?
Anyone able to share a pic of a factory setup?
Old 10-08-2024, 10:57 PM   #24
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yep. Also want to add, that fixed 4-blade fan will likely never pull as much air as a proper 7-blade. Its blades are possibly narrower and have less pitch than a fan that's designed for a clutch unit.
- Mike -
RIP El Jay
Old 10-09-2024, 10:16 AM   #25
kna4977
I know I’ll need a clutch either Hayden 2747 or AC-Delco 15-80245 and a 7 blade fan like a Dynacorn M1017.
I doubt any of the bolts that are on it now will work so anyone know what else I would need for hardware?
