Old 10-08-2024, 02:02 PM   #1
dec010974
dec010974's Avatar
Building a K5 Blazer with a C10 SWB Frame
Hello my fellow Trucksters. As the title reads, I am attempting to build a K5 Blazer with a 1970 C10 SWB frame. My research states that if I remove 11 inches from the frame and modify/fabricate the rear tub mounts, I should be fine. Please chime in. Any information on this subject is greatly appreciated.
dec010974 is offline   Reply With Quote
Old 10-08-2024, 02:48 PM   #2
dagnabbitt
dagnabbitt's Avatar
Re: Building a K5 Blazer with a C10 SWB Frame
As far as I know, that is right. 115 inch frame cut to 104.
I hate it when I ask a question on here and people try to deter me from what I plan to do, so forgive me: why not take a LWB and cut it down instead?
I don't know about your neck of the woods but I would think that a SWB is pretty valuable.
If you already have it you could probably trade it for things you need.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-08-2024, 05:21 PM   #3
dec010974
dec010974's Avatar
@dagnabitt, as with life, I approach everything with a grain of salt. I hear you loud and clear but the SWB fell in my lap. I know the condition of what I have so I thought that would be the best start for me. I also own a 1968 c10, a running/driving truck, LS2/TR6060, Dakota digital gauges, 4 wheel disc brakes, but it’s just a shop truck. It’s not the prettiest but it works. A Midlife crisis kicked and now I want to build a K5 Blazer. So as I narrow down my plan of attack, I am taking notes and gathering parts. So far, I have replaced all the cross members and all the body mounts on this frame. My goal is to build the rolling chassis and buy the K5 tub. In preparation to building the chassis, I want to cut/weld, sand blast/paint the frame but a buddy said he would only cut the frame if he had in his possession the K5 Tub. As I understand his point, I am ready to cut/weld and move forward. Hopefully others will chime in with advice. Thanks for chiming in @dagnabbitt
Old 10-08-2024, 05:50 PM   #4
dagnabbitt
dagnabbitt's Avatar
I totally get it! Please post pics!
I have a cut down 67 K20 and have been kicking the idea around myself.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-08-2024, 06:08 PM   #5
dec010974
dec010974's Avatar
The Parts that I have collected so far are Gen 4 LS 6.0L engine, C10 rear differential with 3.73 positive traction, 4L60E transmission, C10 SWB frame. I have replaced the core support mounts and cross member, Cab mounts, rear frame cross mount, Trailing Arm cross member, Added C-Notch, and frame stiffener. The next step is to cut or not to cut. I have been looking at Blazer tubs to purchase but I want to stay away from body work and rust repair
Old 10-08-2024, 09:48 PM   #6
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: Building a K5 Blazer with a C10 SWB Frame
sounds like a cool project, you've got the know how and ambition, I say go for it. please post some pics as you go.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 10-09-2024, 08:31 AM   #7
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by '68OrangeSunshine View Post
If you want to build a K/5 Blazer, you will need a Dana 44 Front axle, NP205 Transfer case, and a Kay 5, 10 or 20 frame.
Unless your project is a C/5 Blazer, which is what I think you want.
[Without the Four Wheel Drive parts, it's not a KAY/FIVE].
Hey Moderators, do You think this thread should be moved to the Blazer/Jimmy Forum?
Even the 2wd Blazer had K5 fender emblems. I'm not sure how the vin was arranged.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-09-2024, 06:58 PM   #8
dec010974
dec010974's Avatar
This K5 Blazer will be a lowered 2WD Truck. The plan is to have front/rear
coil-overs with the trailing arms, wildwood spindles with big brakes, disc/disc brakes. At this point in collecting parts. The front control will be sourced by PBFab. PBFab makes control arms that centers the wheel in the front wheel. In stock form, the wheels are not centered in the wheel well. I’m thinking a 10 inch cut rather than a 11 inch cut. Like they say measure 10x and cut once.
Old 10-09-2024, 07:09 PM   #9
dec010974
dec010974's Avatar
Midlife crisis build. This the look I am trying to achieve. I want to start with a K5 Blazer Tub.
Old 10-09-2024, 10:08 PM   #10
truckster
truckster's Avatar
I'm sorry. The correct configuration for any Blazer, whether 2 or 4 wheel drive, is topless...
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-09-2024, 10:39 PM   #11
MS66
MS66's Avatar
Sounds like it's going to be a great project. I'm starting with a lwb 2wd frame to put my K5 body on. I don't do much 4wd stuff anymore, so I thought about a street K5 down in the weeds. Buddy has the lwb donor already stripped to the frame.
MS66 is offline   Reply With Quote
Old 10-10-2024, 07:56 AM   #12
dec010974
dec010974's Avatar
@Truckster Awesome.
Old 10-27-2024, 07:56 PM   #13
dec010974
dec010974's Avatar
Hello to all. It’s an official, I am the proud owner of a C10 SWB to K5 Blazer frame. The frame hasn’t made it to the baptism because the tub hasn’t been ordered. I’m contemplating the purchase of a repop blazer tub or possibly using an original. It’s hard to find a descent tub. I see a lot of rust buckets that they want top dollar. My thoughts are to start with fresh tub.
Old 10-27-2024, 07:57 PM   #14
dec010974
dec010974's Avatar
Pics
Old 10-27-2024, 08:11 PM   #15
dec010974
dec010974's Avatar
Parts to go with the frame, C10 rear differential w/3.73 posi traction, refurbished 4L60E, and Gen 4 6.0L LY6. The AFM and DOD have been removed. Like I stated earlier to make this frame a complete roller chassis I need a set wheels, the front Coil-OverKit from PBFab, and the wilwood brake kit.
Old 10-28-2024, 07:23 AM   #16
1970cstblazer
1970cstblazer's Avatar
Unhappy Re: Building a K5 Blazer with a C10 SWB Frame
They do look better topless, and are more fun. HOWEVER, those tops are so fragile and bulky that I have decided to leave mine on because unless I can devise a pulley system in my garage to properly support and lift the top off, it will get destroyed.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 10-28-2024, 10:29 AM   #17
truckster
truckster's Avatar
Mine has been permanently stored since I got my Softopper.
Old 10-28-2024, 12:50 PM   #18
weq92f
weq92f's Avatar
Here's an option. Ran across this at the Texas 10 Nationals back in May.
http://lonestarcarparts.com -- curious I wasn't able to find this on their web site.
email:
LCP@lonestarcarparts.com
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 11-22-2024, 12:15 AM   #19
dec010974
dec010974's Avatar
If anybody has this info on this subject please share. I started this thread to share with other enthusiasts that may want to attempt what I am doing. I would like some frame measurements, from mount to mount, to compare with the swb c10, blazer frame. I visited Dino’s Git Down and saw a few blazer tubs. My c10 swb frame, 11 inches removed, measurements and the repop k5 tub seems to be off. Any help would be appreciated. I’m trying to get the math right before I order the tub.
Old 12-04-2024, 09:10 AM   #20
dec010974
dec010974's Avatar
Pics
Old Yesterday, 12:39 PM   #21
406Weiand142t56ina65
Following as I'd like to do the same thing. Good on you for this endeavor. G
406Weiand142t56ina65 is offline   Reply With Quote
