Old 10-10-2024, 06:01 AM   #1
gmc 2500 4x4
extra parts, clutch rods, peddles
my turn to clean out some parts, not sure what they all fit. upper clutch rods are worn but can be repaired seeing how they are'nt reproduced. im keeping the fork and one good upper rod. measurements are there for the lower rods.
upper rods: 25.00ea
lower rods:15.00ea
z bar:35.00
frame brackets: 30.00ea
peddles: 125.00
cab vents :10.00ea
center support:10.00
lower dash bracket 10.00
seat track 15.00
e-brake peddle 15.00
brake booster complete 75.00
plus shipping, im having issues uploading pics, says contact administrator i'll post them when this gets cleared up
gmc 2500 4x4 is offline   Reply With Quote
Old 10-13-2024, 05:30 AM   #2
gmc 2500 4x4
Re: extra parts, clutch rods, peddles
Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
this is the message i get when uploading pics. never had issues before, and i reached out to administrator with no luck....!
Old 10-13-2024, 08:52 AM   #3
Jason Banks
Jason Banks's Avatar
I find when that error happens. I just need to open the website in a new window and start over. Or maybe I'm able to use the back button and go back a few pages and reload that page and then start over. It's kind of annoying, but usually not something I can't overcome.
Jason Banks is offline   Reply With Quote
Old 10-13-2024, 09:09 AM   #4
gmc 2500 4x4
I just uploaded the same pics to another group and all is fine..
Old 10-13-2024, 10:05 AM   #5
Getter-Done
Getter-Done's Avatar
You can try cropping the pictures.
That works for me.
This website is different than most.
Hope this helps.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 10-13-2024, 10:19 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Your pictures are too big. I size all of mine down to 1150 pixels wide and the board software will handle them from there.
Leon
Old 10-14-2024, 07:41 AM   #7
gmc 2500 4x4
Your right
Old 10-14-2024, 07:45 AM   #8
gmc 2500 4x4
upper rods: 25.00ea
lower rods:15.00ea
z bar:35.00
peddles: 125.00
cab vents :10.00ea
seat track 15.00
More
Old 10-14-2024, 07:49 AM   #9
gmc 2500 4x4
More
More
Old 10-14-2024, 07:49 AM   #10
gmc 2500 4x4
That works for me.
Hope this helps.
It worked
Old 10-14-2024, 12:54 PM   #11
pjmoreland
pjmoreland's Avatar
I'll take the long lower clutch rod, please.
pjmoreland is online now   Reply With Quote
Old 10-14-2024, 02:33 PM   #12
gmc 2500 4x4
OK, zip code ?
Old 10-14-2024, 02:36 PM   #13
pjmoreland
pjmoreland's Avatar
OK, zip code ?
PM sent
Old 10-14-2024, 03:22 PM   #14
gmc 2500 4x4
14'' lower rod sold
Old 10-15-2024, 03:24 AM   #15
pjmoreland
pjmoreland's Avatar
Would you sell just the arm off of that pedal assembly?
Old 10-15-2024, 11:34 AM   #16
pjmoreland
pjmoreland's Avatar
I ended up finding that clutch arm. It was in the crawl space under my house.
Old 10-18-2024, 01:51 AM   #17
pjmoreland
pjmoreland's Avatar
14'' lower rod sold
Received the 14" lower rod today. It looks good. Thank you.
